Head gasket ?
Old Mar 10, 2025 | 02:21 PM
Daniel Yosef's Avatar
Daniel Yosef
Head gasket ?
Hey, got 1967 f100, 352 fe.
truck runs good no leaks or anything unusual. Today I checked as usual the dipstick and saw milky liquid while reaching pretty dang high on the stick. What my options from here and how I’m certain about what can it be? Thank yiu
Old Mar 10, 2025 | 03:10 PM
tcanthonyii's Avatar
tcanthonyii
Could be intake or heads leaking. You can run a test on your coolant to see if you are getting gasses in your radiator. A leak down test possibly as well but the only real way to know what's going on is tear it down and inspect everything.
Old Mar 10, 2025 | 03:15 PM
Daniel Yosef
got you.
so something odd, I ran it for a good 10-15 min. Checked dip stick again.. nothing. Looks like solid oil now.
make sense?
Old Mar 11, 2025 | 01:59 PM
fe390pc's Avatar
fe390pc
It could just be some condensation on the did stick. If its just oil now and not milky you should be fine.
Old Mar 11, 2025 | 02:40 PM
davelj's Avatar
davelj
This time of year, condensation can be an issue. These old engines don't have the same quality PCV systems as newer cars. If it only shows at the top of the dipstick and not all the way down to the end in the oil, you are probably ok. Yet another reason to change oil often on vehicles that you don't drive much.
SuperDuty93
Aug 18, 2013 01:19 AM
69F250CrewCab4x4
Apr 10, 2007 09:20 AM
trent950
Nov 8, 2006 06:27 PM
RustyTrustyF150
Apr 29, 2005 09:28 PM
nmarlowe
Sep 1, 2004 07:25 PM
