idle air control valve
Old Mar 10, 2025 | 12:56 PM
userid22's Avatar
userid22
8th Gear
we had a idle air control over speed error, changed the idle air control sensor valve, checked the connector(11.78 v), error not changed
Old Mar 11, 2025 | 01:25 AM
Don Ridley's Avatar
Don Ridley
You need to give vehicle and engine details.
Old Mar 11, 2025 | 08:41 AM
manicmechanic007's Avatar
manicmechanic007
Your IAC is a solenoid valve
They do get stuck
Did you disconnect it, and the van falls on it's face? (meaning Idles at 550)?
That's generally the first test
Disconnect it and see if the idle changes (it should drop)
Code, year of van and engine trans combo is what we need to really help
Old Mar 12, 2025 | 10:25 AM
Don Ridley's Avatar
Don Ridley
They do get stuck
Also, the IAC is controlled by a PWM signal that can't be accurately measured with a voltmeter (it is PWM on my '97, might be different on older vans).
audioking
Jan 11, 2001 08:08 PM
J.C.
May 30, 2000 07:06 PM
