cowl hood
Old Dec 4, 2003 | 12:29 PM
824x4ride's Avatar
824x4ride
Question cowl hood
a buddy of mine has a fiberglass 3" cowl induction hood for a 71 f-100 by any chance would this hood fit on my 78 f-150 or will the hood be too long? if that one wont fit does anyone know were i could pick up a 3" or more cowl hood fiberglass or steel for my 78 f-150?...thanks in advance
Old Dec 4, 2003 | 12:34 PM
proeliator's Avatar
proeliator
I know the Harwood one fit great on the hood of my '73. Follows the hoods factory lines great. Can't say for sure on your 78 due to the cosmetic changes but at least this gives you a point of refrence. I don't see why it wouldn't fit.
Old Dec 4, 2003 | 01:30 PM
73Custom's Avatar
73Custom
67-72 hoods are the same, 73-79 hoods are the same. The 71 hood may bolt up to your 78, but it won't fit properly. You would be better off finding the correct hood.
Marty
Old Dec 4, 2003 | 02:13 PM
824x4ride's Avatar
824x4ride
thanks for the imput does anyone know a website were i could find cowl hoods for the ole' 78?
Old Dec 4, 2003 | 03:40 PM
proeliator's Avatar
proeliator
Really? I thought there were cosmetic changes in '78 but wasn't positive. If thats the case, the Harwood will work great on your 78. I got mine at summit.
Old Dec 4, 2003 | 04:06 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
I cut in one of the cowl scoops found a big piece of cardboard reached inside with a small pencil and marked the opening use the cardboard to cut the hole. The scoop will slide in from the under side makes a real nice cowl hood find one with out the raised up rib the rib ones look like they should be on the other brand of truck.
p.s. you want have a lot of $$$ in it
Old Dec 6, 2003 | 01:27 PM
Flatbed392's Avatar
Flatbed392
Try Unlimited products---- They have cowl induction hoods up to a 9-inch cowl.
Hope this helps.
Don
Old Dec 6, 2003 | 04:36 PM
mpcrewcab's Avatar
mpcrewcab
another source is http://www.up22.com/ranger.htm they have 4-9 inch cowl hoods---the 73-79 trucks are about 2/3 of the way down the page.
Old Dec 6, 2003 | 04:38 PM
black76f250's Avatar
black76f250
go to www.up22.com they have cowl hoods and they also make them for the ranger and explorers too
Kenworth
19
Apr 21, 2010 01:32 PM
PitbullsAndFords
Sep 21, 2007 12:04 AM
Todd K
Nov 21, 2006 12:14 AM
wheelhoppin67
Jan 26, 2005 06:47 PM
Ryan50hrl
Dec 6, 2001 11:13 AM
