Modular V10 (6.8l)
Coolant pipe under intake manifold
Old Mar 8, 2025 | 12:41 PM
davidaz's Avatar
davidaz
I have a question on the triton 2 valve v10 on the hard coolant pipe under intake manifold. I have the intake manifold off and the two bolts securing the hard pipe to the the cylinder head off also. The pipe is loose now do I just pull it out with a little force from where it is connected to block behind the water pump. And also what type of seal is sealing this pipe to block. Is it threaded inside water pump casing. And how replace the seal. Thanks for any help.
Old Mar 8, 2025 | 12:54 PM
charlie g's Avatar
charlie g
FTE Community Team
if my memory is up,it has a o-ring on it that pushes into the block, years and heat make them hard to remove try pming manicmechanic007 as he's a dealer mechanic with a sharp mind that could tell you for sure
Old Mar 9, 2025 | 11:59 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I'm curious what @davidaz comes up with here . . .
Old Mar 9, 2025 | 12:01 PM
charlie g's Avatar
charlie g
FTE Community Team
a good tug would help, most likely a hardened o-ring stuck in a bore
Old May 7, 2025 | 08:24 AM
davidaz's Avatar
davidaz
Yes it pulls right off and has two o rings fro sealing
PJWhelan
Jan 11, 2023 09:42 AM
bro460
Modular V10 (6.8l)
Jul 21, 2013 07:46 AM
expy1981
Mar 21, 2013 11:46 AM
DallasRanger
1997 - 2003 F150
Mar 27, 2009 10:46 PM
