Truck won't start
Old Mar 8, 2025 | 12:04 PM
Simo1776's Avatar
Simo1776
5th Gear
Truck won't start
Hey guys, I have a 21 F-250 deisel. Tried stating this morning and a bunch of dingers started going on and won't let truck start. Hill descent, cross traffic, engine coolant reading at -76, hill start assist, pre collision, advance track. Anyone know what would be causing this? thanks!
Old Mar 8, 2025 | 12:24 PM
cpobst's Avatar
cpobst
Bad batteries?
Old Mar 8, 2025 | 12:26 PM
Simo1776's Avatar
Simo1776
5th Gear
Batteries were replaced yesterday.
Old Mar 8, 2025 | 12:45 PM
cpobst's Avatar
cpobst
Did it do this before the replacement?
Old Mar 8, 2025 | 12:48 PM
Simo1776's Avatar
Simo1776
5th Gear
I suppose I should have given that info. Yes this happened yesterday as well. It started later on in the day and I then replaced the batteries thinking they were getting old. (They were original)
today now it is not starting at all
Old Mar 8, 2025 | 01:37 PM
longhaultransport's Avatar
longhaultransport
This seems like a battery problem, still.
Check all 4 of the connections, make sure they are good.
I would load test the batteries as well, make sure both are fully charged and healthy.
Did you have a lightning storm recently?
Old Mar 8, 2025 | 06:33 PM
Simo1776's Avatar
Simo1776
5th Gear
Got this figured out after a few hours. The fuse terminal for the ecm is bad. The fuse itself was not blown. I jumped a wire from the drivers side of the fuse to the positive battery terminal to turn on the ecm. Truck fired right up. Will need to replace that fuse box now.
Old Mar 8, 2025 | 06:51 PM
cpobst's Avatar
cpobst
Nice work!
EConner
Jul 3, 2023 10:42 AM
KKCM
Apr 28, 2023 08:38 PM
86F150-Lariet
30
Jul 19, 2006 01:37 PM
REMILLER
May 18, 2003 09:16 PM
