Fuel tank
Old Mar 8, 2025 | 11:12 AM
Grf4413's Avatar
Grf4413
6th Gear
Fuel tank
Wanting to see what your favorite method to fix a tank with rust in it. I've tried the lime-away with marbles, I also used a coating for the inside. Our would it be best just to buy new tank. Thanks ahead for the ideas. The tank I'm dealing with is the aux tank, inside the frame rail at the front of the bed.
Old Mar 8, 2025 | 12:52 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
New repop tank, they are cheap enough and that way your chances of getting the sending unit fuel sock, fuel lines, pump and especially the carb clogged up with "stuff". Some of those inner tank coating kits are known to flake off soon and then the pick up filter is the 1st thing to get clogged.
Spectra makes a nice reopo, most local auto stores can order it. Just make sure when you pick it up that you take it out of the box (RIGHT IN THE STORE) and insp it for damage. Especially on the pinch seam edges.
https://www.oreillyauto.com/detail/c...rd-f-150?pos=0
You can even upgrade to a poly tank and never worry about rust again.
https://www.trexautoparts.com/produc...ear-tank?gQT=1
https://autokrafters.com/fuel-tank-1...mts4250/?gQT=1
Make sure you get the tank that either does or does not have the EEC (roll over) valve on the top. If yours does have it, then you need to get that same style. That way you fill neck and vent lines will be the same.
FlyJSH
May 30, 2024 04:59 AM
HurtinAlbertan
Jul 20, 2021 11:34 AM
DesertSmoker
15
Aug 11, 2020 06:06 PM
granny_rocket
Jun 8, 2013 06:40 AM
johaner78
Aug 30, 2009 08:21 PM
