Terminology assist?
Old Mar 5, 2025 | 07:40 AM
sjmooney1's Avatar
sjmooney1
5th Gear
Terminology assist?
So the following description is being used by Amazon for selling a Motorcraft coil and I am not sure what stripped means, the only place I ever saw the term used in description, they are selling it new in package, any thoughts? Thanks
Motorcraft Ignition Coil With Boot for 2019 Ford E-Series, Stripped - DG571
Old Mar 5, 2025 | 07:46 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Old Mar 5, 2025 | 08:12 AM
drj564's Avatar
drj564
Not sure about stripped but I hear to stay away from Amazon if wanting to purchase genuine Motorcraft parts.
Old Mar 5, 2025 | 11:18 AM
jimzpsd's Avatar
jimzpsd
From what I see on the add, it points out that it fits "stripped chassis" models too.
Amazon Amazon
Old Mar 5, 2025 | 12:16 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The E-Series "Stripped Chassis" is just that, a new chassis that is stripped of all body components. A bare chassis without a body or cab, but that otherwise has everything needed to operate as a running chassis.
It is essentially an E-Series Cutaway (an Econoline cab cut away at the B pillar with an open back)... stripped of even the cutaway cab, leaving just a bare chassis of frame, drivetrain, and small instrumentation cluster, for use as a platform to build lighter duty step vans, parcel vans, walk in vans, and specialty vehicles.
The platform codes of an E-Series stripped chassis are E3K and E4K. These platform codes are used by Ford in the ordering systems, as well as in the VIN.
For example, my FTE username has a platform code of W57, where the W designates Crew Cab F-Series, the 5 designates Class 5 for F-550, and the 7 indicates 4 wheel drive. A current model year code equivalent is W5H (H replaced 7).
I mention my own vehicle's model code as a Class 5 weight class vehicle, because when most people think of Ford stripped chassis models, they think of the F-53 for Class A Motorhomes, and the F-59 for UPS and FedEx type parcel delivery walk in vans, such as those completed by Ultilimaster, Morgan Olsen, and the like. The F-53 and F-59 are both Class 5 (and Class 6) stripped chassis models, ranging from 16,500 lbs GVWR to 22,000 lbs GVWR (roughly speaking... exact GVWRS offered differ by model year).
However, Ford also offers lighter duty stripped chassis models, based on the E-Series RV Cutaway platform, without the Cutaway cab. The GVWRs for these stripped chassis models range from 11,500 lbs (E3K) to 14,500 lbs (with 6.8L V10), but for models equipped with the optional 6.2L gas engine in 2019, the highest GVWR is limited to 14,000 lbs. (E4K).
Old Mar 5, 2025 | 06:28 PM
sjmooney1's Avatar
sjmooney1
5th Gear
Now that was an amswer!
Thank you for taking the time to explain the time explain that to me and anyone else who might encounter a similar type situation.
Arthur cormier
Computer Chips & Tuners
Aug 4, 2021 10:55 AM
seagull369
Jan 20, 2014 03:18 PM
Walston
Jul 11, 2010 06:36 AM
eigenvector
1983 - 2012 Ranger & B-Series
Aug 26, 2006 08:35 AM
chrono4
General Automotive Discussion
Jan 1, 2005 10:50 PM
