Clockspring?
Old Mar 1, 2025 | 12:34 PM
Vexmoticon's Avatar
Vexmoticon
7th Gear
Clockspring?
Hey all, this is my first post on here so sorry for poor wording if so
I’m having some slight issues with my 1994 F-150 5.0, the ABS light is on, the horn doesn’t work, and cruise control doesn’t work, now there are more issues of course but this is what I’m focusing on right now. From what I’ve seen here among other places is that the most likely culprit is the clock spring, and while normally I would go gung ho and order it the only thing that makes me question it is that there’s no airbag light on. I’ve already checked all fuses and the horn itself works and I’ve checked all my abs sensors and they all seem to be in good shape
I just want to look at my options before I order a $140 part and it doesn’t work
All input is appreciated!
Old Mar 2, 2025 | 08:12 AM
Scndsin's Avatar
Scndsin
Welcome to FTE.
I "got here" doing a google search for no horn, no cruise, flashing air bag light.
Does the air bag light self test at key on?
You only have 1 sensor for your "RABS" (rear anti-lock brake system) & it lives in the pumpkin & gives a lot of other systems info to make calculations with.
It sometimes has a build up of metal on its magnet.
There is a test of the RABS module that can be performed by grounding a wire to make it flash numerical code. ( but it escapes me at the moment)
Hopefully someone will post it up & give you some better trouble-shoot advice.
Old Mar 2, 2025 | 07:40 PM
manicmechanic007's Avatar
manicmechanic007
Count the flashes of the airbag lamp
If it comes up a clockspring code, you are on the right track
And
Your 1994 does not have a separate horn ring in conjunction with the clockspring
I would plug an air bag simulator into it and see if the air bag lamp goes out
I would also plug my NGS into it and see what It said
You will have a hard time doing that, (the NGS) but the simulators are out there
I sure would verify the clockspring was plugged in, (before ordering one) and make sure the wiring was intact (what you can see anyway)
I have a few of those air bag simulators if you want to borrow one
They make the airbag lamp diagnosis for an open clockspring a snap
Look into those for your truck
Old Mar 2, 2025 | 10:26 PM
Scndsin's Avatar
Scndsin
I asked if he has the key on self test illumination.
Originally Posted by Vexmoticon
...the only thing that makes me question it is that there’s no airbag light on. I’ve already checked all fuses and the horn itself works and I’ve checked all my abs sensors and they all seem to be in good shape...
Old Mar 3, 2025 | 02:58 AM
manicmechanic007
Mis read
I thought the airbag lamp was "on"
Old Mar 3, 2025 | 08:08 AM
Vexmoticon's Avatar
Vexmoticon
7th Gear
Okay so
You were right when you said I was overthinking it and I have figured out the ABS light issue, so now the light is off but I’m still having the no horn issue
I haven’t quite been able to check the Cruise Control yet as I’ve not got all the parts back onto the truck but as soon as I test I’ll update, and while I’m at it I’ll go ahead and get a wheel puller to check the clockspring
The airbag light does do a self check when it turns on but doesn’t flash or stay on, the bulb was originally burnt out though so maybe there was an issue before? Regardless it’s not on now so that’s not too much part of my worries
I guess my question now is could the airbag light not be on but the clock spring still be out?
Old Mar 3, 2025 | 07:26 PM
manicmechanic007
Well, the clockspring has about 6 gold ribbon wires
Any one of them could be broken causing the horn issue
There is also the horn switches. At this point if everything else works, I would sure get at those horn switches and the horn relay for a few tests
Those switches will ground the wire that makes the relay deliver the B+ to the horns
So, you're looking for the ground that the horn switches provide to the horn relay
I'd sure make sure that signal was "not" there before ordering a expensive clockspring
torq'ta 5 8's Avatar
torq'ta 5 8
yes, yes it could, good read here-->Clock Spring Removal and Installation | Bronco Forum - Full Size Ford Bronco Forum
BHUNT300
Nov 29, 2015 06:28 PM
charredskin
Oct 10, 2006 06:42 PM
nalts
Jun 8, 2006 06:49 AM
