2005 e150 5.4l motor
Old Feb 27, 2025 | 09:57 AM
billybob12648's Avatar
billybob12648
Hi and help please---getting codes 2106 and p061b together with wrench icon and limp mode. I replaced the tps and cleaned maf and checked for air leaks at air box with no change. The abs light has been on for years but never an issue. Any ideas y'all??
Old Feb 28, 2025 | 04:14 AM
manicmechanic007's Avatar
manicmechanic007
Better plan on a few pinpoint tests in the '05 PCED
The P2106 is the TP sensor not jiving with the throttle actuator TP
That is a limp mode generating code to prevent engine damage
Both of those codes can be set by a dirty MAF sensor hot wire
I'd clean and inspect the MAF, then clear codes and reset
Your air filter is not dirty as hell is it?
Old Feb 28, 2025 | 12:57 PM
billybob12648
Thanks for the reply. I have cleaned the maf sensor but will do again. You said clear the codes then RESET--how to reset??? The air filter only has 4k miles on it. Bill
Old Feb 28, 2025 | 07:26 PM
manicmechanic007
Sorry, should have said clear codes and retest
camlmfao
2004 - 2008 F150
Sep 1, 2021 10:07 AM
cherokeexj32
Oct 15, 2016 07:54 AM
Tuff4stroke
Apr 15, 2012 03:44 PM
