Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Unlock CURT Rebates with CARiD I Up to $60 Off Trailer Accessories
Old Feb 25, 2025 | 06:07 AM
carid's Avatar
carid
Former Vendor
A good rule of thumb before your next big adventure is to ensure your truck is properly matched with your trailer, fifth wheel, RV, camper, or other towable equipment. CURT towing supplies feature industry-leading designs, engineered to enhance your hauling capabilities and ensure ideal trailer alignment with your truck.
In this post, we’ll review four of CURT’s trusted towing solutions and highlight fantastic rebate offers to help you find the perfect setup that balances cost and suits your budget. Whether you're towing heavy loads or seeking a smoother, safer ride, CURT products offer unmatched reliability and performance. Don't miss this chance to save, claim your rebate today!
Keep reading for details and choose the perfect towing solution for your needs.
$30 Rebate with the purchase of an Echo® In-Line Trailer Brake Controller
For drivers who need a tool-free brake controller setup and smartphone-controlled braking, we recommend the CURT Echo® In-Line Trailer Brake Controller. It is a state-of-the-art, wireless brake controller made for a modern towing experience, it installs between your vehicle and trailer, eliminating the need for traditional wiring inside the cab. Plus, it syncs with your smartphone via the Echo® Smart Control app for seamless operation.
CURT® - Echo™ Under-Dash Trailer Brake Controller
Notes:
  • Avoid distracted driving. Only make adjustments when the vehicle is stationary;
  • If Bluetooth connection is lost, the brake controller will continue to function safely, using the most recently programmed settings;
  • Not compatible, but will not interfere, with Apple CarPlay or Android Auto;
  • Compatible with Echo manual override button #51189 (sold separately) for hands-free driving;
$50 Rebate on the TruTrack® Hitch-Mounted Weight Distribution System
If you’re often towing travel trailers, campers, and utility trailers, consider TruTrack® Hitch-Mounted Weight Distribution System as your primary option. It improves towing stability by distributing weight and integrating sway control. Unlike traditional setups that require additional sway bars, TruTrack® features built-in sway control for a safer and smoother towing experience.
CURT® 17499 - TruTrack™ Light-Duty Weight Distribution System (500-800 lbs TW / 5000-8000 lbs GTW)
Specifications:
  • Gross Trailer Weight(GTW) 5000 lbs - 8000 lbs;
  • Finish Carbide Black Powder Coat;
$50 Rebate when you purchase the True Course Advanced Bluetooth® Trailer
The True Course™ Advanced Bluetooth® Sway Control System is an innovative solution that actively reduces trailer sway and works with trailers up to 10,000 lbs. Using Bluetooth® connectivity for real-time monitoring and adjustments and an advanced motion-sensing system, it automatically applies braking force to stabilize the trailer, all while being controlled via a smartphone app.
$60 Rebate with the TruTrack® 4P Trailer-Mounted Weight Distribution Hitch
Finally, last but not least, the TruTrack® 4P Weight Distribution Hitch is manufactured to take stability to the next level with an integrated four-point sway control system. It evenly distributes weight while actively resisting trailer sway, making it one of the most advanced weight distribution hitches available so far.
Choosing the right accessories can make a significant difference in towing performance. With CURT you can be sure that your truck is up to any towing task you might think of.
Explore our complete line of CURT towing products aimed to make your haul safe and smooth.
Old Feb 25, 2025 | 06:10 AM
carid's Avatar
carid
Former Vendor
Upgrade your towing setup and save big with our limited-time CURT promotions!
Which of these rebates interests you the most: $30 off the Echo® Brake Controller, $50 off the TruTrack® or True Course™ Sway Control, or $60 off the TruTrack® 4P?
Let us know what you need for a smoother, safer tow!
carid
Jan 20, 2020 07:56 AM
Torklift Sheryl
May 22, 2018 07:43 PM
Torklift Sheryl
Mar 6, 2018 07:25 PM
Torklift Sheryl
Sep 26, 2017 04:38 PM
carid
May 29, 2017 08:13 AM
