Truck Stalling
Old Feb 23, 2025 | 11:33 AM
john ulrich's Avatar
john ulrich
Trailering
Truck Stalling
I have a 2006 F150 4.6 Liter truck with 270000 miles on it. When I come to a stop the motor is dying out sometimes. for example, I come up to stop sign and it will just die. I just had new plugs put in it last week. It doesn't die all the time just randomly. Any help would be appreciated thanks
Old Feb 23, 2025 | 12:05 PM
jr105's Avatar
jr105
I would start out by cleaning the throttle body.
Old Feb 23, 2025 | 02:41 PM
john ulrich
Trailering
Ok thanks I will give it a try
Old Feb 24, 2025 | 05:11 AM
techrep's Avatar
techrep
and check the condition of the FPDM located on the frame rail above the spare tire.
Old Feb 24, 2025 | 01:02 PM
VEGASHANDYMAN's Avatar
VEGASHANDYMAN
4wd High
i have had similar problems with my 04 5.4 3v and in the past the idle air control valve is one thing to check, also check your fuel pressure with a scanner and if there are no codes then check your maf it could be dirty or it could be the fuel pressure regulator and then of course check your truck for vacuum leaks on the intake or with the purge valve? coukd be getting to much evap and when you are still it's not suoposed to draw vacuum only when the truck is in motion and if its still drawing vacuum meaning always open the truck coukd be sucking in to much vapor even fuel and choking it out so to say
Old Feb 24, 2025 | 03:56 PM
john ulrich
Trailering
Thanks i plan on diving into it this weekend
Cflo93
2004 - 2008 F150
Jul 26, 2024 05:40 AM
Chris Karsseboom
2004 - 2008 F150
Mar 10, 2017 08:47 AM
mwkobe
2004 - 2008 F150
Apr 9, 2011 06:38 AM
90ford4x4
2004 - 2008 F150
Feb 15, 2008 08:53 PM
netek018
May 15, 2007 10:00 PM
