need help on water guage
Old Dec 3, 2003 | 09:54 PM
Fishrman's Avatar
Fishrman
Question need help on water guage
Hello, I have a 83 F250 with the 351 in it. I bought a used aftermarket water temp guage from a friend of mine. I took the old water temp sensor out of my intake, and noticed that the new one was too big to fit. so I took the outer ring off that had threads on the outside. I was left with the sensor and another ring with threads on it that could move up and down on the wire freely. so that fit in my intake. I screwed it in as tight as I could with the little space available. I started the truck and it was leaking just a little bit out of the intake where it went in and the temp was registering on my guage. It was working good when I revved it up and all of a sudden the guage went down to 0. and it wont work anymore. i am guessing that the guage just went bad, but i dont know what for. but if any of yall know what i've done wrong or have any suggestions..i would appreciate it. thanks.
Old Dec 5, 2003 | 12:18 AM
f100guy's Avatar
f100guy
to fix the leak put some thread sealer on it or pipe dope as we plumbers call it. anyways i would check the wiring. maybe a fues blew if you hooked it up through the box. or a wire came loose when you revved it up. if not get a new sensor.
