Steering column floor plate
Old Dec 3, 2003 | 09:44 PM
joners's Avatar
joners
Exclamation Steering column floor plate
Does anyone have a picture of the cover that goes on the floor? I lost mine and I need to get one made up....Where does the steering column go on the plate, dead center? upper or lower center? I guess if I make my own, I can put it wherever to meet my needs so it clears my headers?
Old Dec 4, 2003 | 06:35 AM
ke6bnl's Avatar
ke6bnl
Re: Steering column floor plate
I may have the plates I replaced mine and made one for a tilt steering and flaming river u joints. Ed ke6bnl IIrc there are more then one plate to the opening.
Old Dec 4, 2003 | 07:04 AM
ferguson777's Avatar
ferguson777
Joners,
If you can wait a few days, I could dig mine out (for a 54), trace it, scan it and mail it to you.
Let me know.
Old Dec 4, 2003 | 07:35 AM
merc546's Avatar
merc546
Hi,
I mounted my steering column first then made plate to fit opening it ended up being a lot higher up the toe board then the original opening. You can see picture in my gallery
You need to have the seat installed also so that you can get a comfortable angle on the column.
Chuck
Old Dec 4, 2003 | 10:45 AM
fartruck's Avatar
fartruck
The Plate is made up of three pieces to fit around steering column. You can actually pull the steering box up thru the hole. Would be easier to get one from a wrecking yard then try and fabricate the whole thing. Take a 5/16" nut-driver with you, as there are many self-tapping screws.
Old Dec 4, 2003 | 03:47 PM
joners's Avatar
joners
I am using an Ididit Column. I can trace it from the floorboard's it self and relocate to where ever I need it.
merc546, I will probably fab something up just like yours is.
Old Dec 5, 2003 | 06:10 AM
gtkane's Avatar
gtkane
If the '56 floor plate is the same,you can have mine-both pieces and the seal.
Just let me know asap-I am moving soon and will be packing up the pieces soon!
Graham
Old Dec 5, 2003 | 03:33 PM
joners's Avatar
joners
I think it is, I'll take it for sure!
email me, it's my user name at shaw.ca
Old Dec 12, 2003 | 05:50 PM
joners's Avatar
joners
gtkane, so???
Old Dec 13, 2003 | 03:04 PM
jniolon's Avatar
jniolon
old and in the way
column
Steve,
which IDIDIT column did you buy ??
john
Old Dec 13, 2003 | 03:44 PM
joners's Avatar
joners
I got it through Midfifty....
Not sure how long but it was just the plain steel one.
It has tilt with no shifter arm.
Old Dec 14, 2003 | 10:38 AM
gtkane's Avatar
gtkane
Joners
Sorry about the delay,things have been hectic around here (packing and all).
I will e-mail you this week and arange to drop off the parts to you.
Graham
