Still the same 302?
Old Dec 3, 2003 | 09:19 PM
geokel1014's Avatar
geokel1014
Still the same 302?
I have an opportunity to get a 302 block that has already beenm bored 30 over and has the right sized pistons and rings. The block is from a 1975 car, will it still work for a 91 F150 with speed density? I'm not build it to race, just slightly better than stock. Keeping speed density but might try to upgrade to GT40 or GT40P heads. All help appreciated. Thanks
Old Dec 3, 2003 | 10:03 PM
fordeverpower's Avatar
fordeverpower
i don't know if they work and would be very surprised if they do. Gt 40 are damn good heads.
Old Dec 3, 2003 | 10:39 PM
f100guy's Avatar
f100guy
it should bolt up and work perfect
Old Dec 5, 2003 | 09:22 AM
geokel1014's Avatar
geokel1014
My main question is if all accessories will bolt up - A/C, alternator, power steering pump. Are the bolt holes still going to be the same.
Old Dec 5, 2003 | 09:43 AM
f100guy's Avatar
f100guy
yes they will work just don't put the heads on backwards and you will wave the right holes. but you will need take the mechanical fuel pump out and put a block off plated in it's place. they have them at oreilys.
Old Dec 5, 2003 | 08:05 PM
ground_poundin's Avatar
ground_poundin
your oil dip stick is different, use the truck cover and u wont have a dip, use the other one the dip might not clear the brackets. try to get your pan modified with a dipstick hole like the later cars
Old Dec 8, 2003 | 07:30 AM
85 bronco xlt's Avatar
85 bronco xlt
I went thru this.
Heres what I found.
most everything will work. I had to swap the water pump to get the brackets to bolt to it.
I had major problems with the serpentine belt so I went to a more simple v belt setup.
Reason I did this was to dump the ac and the smog pump.
I went to junkyard after junkyard huntting the brackets...no 1 had them
I finaly broke down and called ford and they actually still had the brackets I needed in a warehouse in TN
fairly cheap
The dip stick I just used a aftermarket chome one.
Filled it up and marked the oil level full on the stick with a file.
Heres another note on this
When you plan this swap figure out how long you think it will take and double it.
Take that number and double it again.
My two week project has turned into almost 3 weeks now due to huntting parts and cold crappy weather
Old Dec 8, 2003 | 05:47 PM
f100guy's Avatar
f100guy
if this is going to be a carbed motor with a serpentine belt system
because the mechanical fuel pump is in the way for the brackets.
Old Dec 10, 2003 | 06:20 PM
adilts2002's Avatar
adilts2002
i know this is very strange but a chevy big block has the same blocking cover for a fuel pump as a ford small block the seel them at autozone for like10$ about the biggest thing is going to a 91 if u use the serpintine system u have to get a reverse flotaton pump in 87 the changed the flow along with putting the serpintine belt system so get a ater pump off a 91 and should work fine.
Old Dec 22, 2003 | 06:28 PM
bradleygt302's Avatar
bradleygt302
i believe the main difference in the blocks are the 75 block is it made for a 2 piece rear main seal where something like 82 on up are made for one piece rear mains.
Old Dec 22, 2003 | 06:49 PM
f100guy's Avatar
f100guy
i think they changed the main seals in 86 or something. i have an 84 that was 2 piece seal and i have a 90 with a 1 piece seal
Old Dec 22, 2003 | 07:53 PM
adilts2002's Avatar
adilts2002
it was 86 where they changed them in 86 they had both depending on the date of birth
