Need help, what went wrong?
Old Dec 3, 2003 | 07:47 PM
PhilipC's Avatar
PhilipC
I have a 92 Explorer 4 liter 4x4. Today it started making some strange noises while idling, then almost died. I turned the fan off, it was still doing it. Turned the defroster off and that seemed to be the cause of the problem. It smelled like something was burning. Anyone have any idea what needs fixing? I appreciate any help!
Old Dec 3, 2003 | 08:19 PM
kclyki02's Avatar
kclyki02
sounds like an IAC problem.
Check out this page:
https://www.ford-trucks.com/forums/s...hreadid=166103
Old Dec 3, 2003 | 09:48 PM
Opera House Works's Avatar
Opera House Works
Unplug the connector on the compressor
The one that goes to the electric clutch. Sounds like compressor is jammed. This will allow you to use defrost and decide over winter if you want AC that bad.
Old Dec 4, 2003 | 03:42 AM
PhilipC's Avatar
PhilipC
Thumbs up Thanks
Thanks guys, I disconnected the harness at the top of the compressor/clutch and everything seems to work. Does this just allow the belt to freely turn the compressor pulley (I don't know what it's actually called, the wheel on the compressor)? Also, what would happen if the AC were accidentally turned on, nothing? Thanks again!
tfs2403
Nov 24, 2014 10:19 AM
pablocruz69
Jul 19, 2012 12:37 AM
asteig
2004 - 2008 F150
Aug 25, 2009 08:08 PM
vivojr21
Jul 31, 2008 11:25 AM
packrat56
22
Sep 26, 2007 11:03 PM
