Strait axle swap
Old Feb 12, 2025 | 01:05 PM
CarterMain's Avatar
CarterMain
4wd High
Strait axle swap
Hey im trying to do a striaght axle swap on my 1980 ford f250. Has a ttb with a 3:54 gear ratio. What would be the best front axle gear ratio to look for? Is 3:54 offered in a dana 60?
Old Feb 12, 2025 | 03:24 PM
Franklin2's Avatar
Franklin2
Yes they do. I picked a 1989 F350, here are the ratios available that year. Probably can get this ratio most years, 1985.5 up to 1998 F350. 1985.5 was the first year they put the straight axle in the f350. Even a 1980 f350 had the TTB originally.
(Spicer 60, mono-beam), ABS, 3.54 ratio
(Spicer 60, mono-beam), ABS, 4.10 ratio
(Spicer 60, mono-beam), w/o ABS; 3.54 ratio
(Spicer 60, mono-beam), w/o ABS; 4.10 ratio
1989 Ford Truck-F350 not Super Duty (1997 Down)
Axle Assy Fr
Old Feb 13, 2025 | 12:20 AM
My4Fordtrucks's Avatar
My4Fordtrucks
That is the only ratio to look for unless you plan on changing the ratio in the rear axle.
KRoD
Feb 3, 2024 06:19 PM
Christopher Layton
Nov 12, 2015 04:15 PM
Twistedtesty
May 24, 2010 09:58 PM
stumpthumper
Oct 28, 2002 01:06 PM
