Sponsored by: Real Truck
Limp mode every 400+ miles
Old Feb 9, 2025 | 09:03 AM
Mustangboi2006's Avatar
Mustangboi2006
5th Gear
So I picked up a decent 2005 F250 4x4 with the 5.4 L 3 valve. The guy that had it before said it would go into limp mode with slight dead pedal until about 1/4 pressed. He replaced the throttle body and recently I had a wrench and check engine come up and the idle speed was a little high causing the transmission to downshift hard coming to a stop and threw a flashing tow/haul light of a stuck shift solenoid but I think was due to high idle upon stop. The only two codes that would periodically come up was p2106 and p2135. I also recently replaced the complete gas pedal. I haven't performed a throttle body reset or anything. But already after shutting off truck and restart, it runs and drives perfect again. Just kinda stumped and wonder if this might be a PCM issue, mass air flow sensor..... ??? Anyone else ever had this happen?
Old Feb 15, 2025 | 08:19 AM
Mustangboi2006
5th Gear
So far been running good for over a week
So after performing throttle body reset it has so far been running great and not throwing lights or going into limp mode. I'm hoping this got to the other side of the issue
Old Feb 15, 2025 | 06:12 PM
'89F2urd's Avatar
'89F2urd
Sorry no1 responded. If you continue to have troubles, post again.
AaronzDad
Feb 9, 2025 08:42 AM
surfref32
Apr 5, 2021 04:50 AM
cjben
Aug 28, 2016 08:45 PM
10bender24
2004 - 2008 F150
Oct 11, 2011 10:33 PM
crewsd
Feb 16, 2008 07:36 PM
