no start
Old Dec 3, 2003 | 02:04 PM
cutt's Avatar
cutt
no start
i have 86 150 302 FI that wont start.it has fire and fuel but the injectors are not pulsating.what is suppose to tell the injectors to pulsate?i'm thinking it could be the module&stator but i want to be sure
Old Dec 3, 2003 | 08:14 PM
dashashopdog's Avatar
dashashopdog
sounds like a wiring problem. the 5.0l recieved their reference signal from the ecm, which recieved it from the dist. since you have spark you probably nee to trace the wires from the injectors to theecm. there is four of them, two for one side, and two for the other. if that checks ok, you may have a bad injector driver bad in the ecm, but it is unlikely you lost both idm's more likely you lost the splice holding the wires at the harness.. Kurt
