Truck won't start
Old Feb 5, 2025 | 12:26 PM
Fat&Bald's Avatar
Fat&Bald
Truck won't start
Truck won't start off the key but will roll start. What am I looking for here, starter solenoid, starter or ??
Truck is a 78 F250 400/4 speed
Old Feb 5, 2025 | 03:32 PM
FuzzFace2's Avatar
FuzzFace2
A little more information and a lot more testing before you fire the parts cannon at the truck.
What is the volts in the battery?
Dose it do anything when you turn the key to start like a click?
What happens if you run a jumper from the battery + to the small stud on the solenoid with the "S" make sure the truck is out of gear and tires blocked so it dose not roll.
If you want to get real fancy do a voltage drop test on the start system. https://www.ford-trucks.com/forums/1...w-starter.html
Dave ----
Old Feb 5, 2025 | 07:15 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Well with that level of information, I might suggest anything from you need to rebuild the motor or check the blinker fluid reservoir. Lol X2 we need more info, multimeter battery test showing how much volts ? Does it turn over, but not start. No turn over? Turn over slow, is this a new issue (like 1st time ever) or one that have been happening for a while or every so often? X2 safety stuff and have you tried to jump the solenoid? Once you roll start it, does it run fine, any RED Alt light on? Does it restart after rolling it the 1st time?
Michael Lizotte
1997 - 2003 F150
Aug 27, 2024 04:18 PM
cwwwwww7
Oct 7, 2021 09:47 AM
Chris Tomlinson
Apr 30, 2021 08:35 AM
FordYoungGun35
Mar 2, 2013 05:35 PM
Franko72
27
Jan 13, 2010 07:42 PM
