Step bracket trade?
Old Feb 2, 2025 | 10:12 AM
STX Screamer's Avatar
STX Screamer
Step bracket trade?
I have F150 step brackets that I would like to trade for standard Super Duty step brackets. Anyone interested? I am in AZ. Each of us shipping our brackets is okay with me.
The Super Duty brackets let the steps sit 3 inches lower. They are completely interchangeable. I have done this twice before.
Old Feb 3, 2025 | 01:39 PM
jefe4x4's Avatar
jefe4x4
I went the other way going to brackets closer to the body to improve breakover angle.
And there are different versions for different truck configs all using the same brackets and hardware but a different step.
The plastic steps are cheaply held on to the brackets by brass inserts screwed into plastic with metal bracket screws roughly screwed into the step.
Care must be taken when disassembling the brackets from the step.
After destroying a factory step via a big rock, I loosened the brass screws with a power screwdriver which bunged up/heated the threads so badly as to make the step not reusable.
Ford's engineers figured there would never be any upward pressure on the step, only downward so why not cheap out and and use plastic threads to hold the inserts and step down.
Ford sells the whole assembly, both step and brackets as a unit for each of the 3 or 4 versions.
My advice is to trade the entire step/brackets/hardware as a unit, making sure the model truck is the same.
I'm sure there off roaders on here that would like higher up steps.
BTW, in my photo below, I still had the stock step height.
RedRage
2015 - 2020 F150
Apr 26, 2020 09:36 AM
Robertb4wd
2015 - 2020 F150
Jun 29, 2019 02:34 AM
bronco cam
1978 - 1996 Big Bronco
Sep 11, 2002 09:24 PM
