Voltage regulator
Old Feb 2, 2025 | 12:22 AM
saauvenshine's Avatar
saauvenshine
Voltage regulator
Needing to change voltage regulator on 54 ford truck that has been converted to 12 volts. It has a 12-volt regulator on it and want to put a brand-new one. Would I have to do anything to the voltage regulator or generator to make them compatible or match up.
Old Feb 2, 2025 | 04:08 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Well, first, the new voltage regulator will need to match up with the rest of the system. It goes beyond just "12 Volts". Basically there are two types of systems - Type A and Type B, so you need the same type of regulator to match your system. From there, you need to consider the current ratings/requirements and ensure that also lines up.
After the proper regulator has been obtained, then one typically flashes or polarizes the generator in accordance with the system type:
Mjac167
17
Feb 16, 2024 10:04 AM
Gwencon
Apr 14, 2016 08:57 PM
61 uni
Oct 17, 2009 10:07 PM
adbecker
Oct 11, 2000 12:20 PM
