2004 5.4 engine swap 3 valve to 2valve
Old Feb 1, 2025 | 01:48 PM
RudeDog357's Avatar
RudeDog357
4wd High
Can it be done can I make my 2004 a 2 valve 2004 f150 3 valve if not what would my options be
Old Feb 1, 2025 | 03:40 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Not easily. The 2V 5.4 uses old fashioned cable throttle while the 3V uses electric throttle. If you can figure out how to meld those setups together, you’re golden. Probably lots of splicing and an intake swap, for starters.
If you just want to get away from a 3V engine at any cost, a same body truck 4.6 would drop right in. It was a factory option, after all.
ETA: I am led to believe the E-vans that still used the 2V 5.4 to their end were electric throttle as well. But, I’m not sure what engine harness differences there are and what needs to be done to make work in your truck. Splicing, probably. Probably need to work with PATS as well.
perryg114
Feb 27, 2024 09:12 AM
mattsautobody442
2004 - 2008 F150
Sep 1, 2009 02:23 AM
DALEDIESEL
Nov 27, 2007 08:53 PM
Sagegrouse
Mar 3, 2006 08:16 PM
guitar4him
Dec 28, 2002 09:37 PM
