21475963[/url]]How I did it is in the link I provided as well. A 1/4" drive flex socket and flex ratchet was key.
Oops. I remembered you’d posted above but didn’t remember you’d linked to your install. Thanks. I wish I’d have read your install info again before installing mine!
Yes that tool setup would have worked well. I had 14mm 1/4”, but no 15mm.
Also went back and corrected the bolt head size based on the info in your instructions.
Just a thought on the powermaster clearance issue. How about replacing the provided flanged hex bolts with socket head bolts and washers? A hex key socket should have plenty of clearance around the starter body.
Ok, just replaced the starter with a Power Master, really not that bad getting the top bolt in. 15 mm flex socket, extension and flex head ratchet, Snap on flex head torque wrench finished it up.
Definitely make a couple of studs to guide and hold starter in place.
Probably took an additional 5 minutes
