Got my truck back from the body shop after an early morning run-in with a deer. The headlight was smashed in and shorted for a few minutes before I switched it off so I'm assuming its fried because I now have a short when its pulled halfway out the circuit breaker keeps tripping. Oddly enough fully pulled out it doesn't trip or draw insane amounts of current.
Who has the best replacement switch? Mine looks to be original.
Also the service book shows a tool to get it out with, can those still be found?
I would bet the short is in the wiring to the front marker light. The way the headlight switch works, when halfway out the marker lights are on, but they are off when the headlights are on (switch out all the way).
Matt, can you post a picture of your truck. Your signature says "1950 Ford F-1 stake bed" but your icon picture looks like a bigger flatbed with dual wheels. Or do you have 2 trucks?
I'm really stuck as to what is causing this, halfway pulled out it pegs the ammeter into discharge, which I'm assuming is a short, trips the breaker. With it pulled out all the way all my lights are on as normal and nothing appears to be wrong.
The parking and tail lights come on until it trips.
With the stock wiring scheme, the park lights are only on with the switch **** pulled half way out on the 48-50 models. Things get messed with over time - check everything.
If your wiring is stock (even if it has been rewired) you're hunting the BY (blue/yellow-tracer) wire for the park lights. Where it comes out of the harness and connects to the driver's side park light, you should have a double bullet connector so your cross over wire can carry juice to the passenger side light.
I'm betting they wired something wrong when it was repaired that causes the dead short on the park light circuit. These are pretty simple to work with. It has to be that.
