Low speed detonation
Old Dec 2, 2003 | 09:59 PM
saskatchewan's Avatar
saskatchewan
Hi there
I have issues with low speed detonation.
I took it to an auto parts store and they tried doing an OBD II scan on it. Nothing turned up.
I tried changing the spark plugs from NGK V plugs to Autolite double platinum and that made a difference but there is still some dieseling when it is at operational temperature.
I have tried the de-carboning treatments. That made no noticeable difference.
Could it be something in the throttle body or, could it be a problem with a ground wire?
Thanks
Old Dec 2, 2003 | 11:35 PM
hreed's Avatar
hreed
Pretty hard to troubleshoot without knowing anything. How about make, model, year, engine etc, etc. Thanks
Old Dec 3, 2003 | 08:39 AM
saskatchewan
hey
It is a 1995 Ranger with a 2.3 litre engine
Old Dec 3, 2003 | 12:13 PM
Ken00's Avatar
Ken00
Cleaning the MAF senser might help.
Old Dec 3, 2003 | 02:41 PM
saskatchewan
hey
Is that sensor in the throttle body?
Old Dec 3, 2003 | 02:52 PM
seagull369's Avatar
seagull369
Shot in the dark here, but did you check the timing on your truck??
Old Dec 3, 2003 | 02:55 PM
jlb46's Avatar
jlb46
I had the same problem on my Z28 and cleaning the Mass Airflow Sensor (MAF) did the trick. Its located on the intake elbow between the air filter box and the throttle body. It comes off pretty easy by loosening up a few screws and unpluging the wire, then just spray it down with some carburator cleaner, but don't wipe it with a rag, or jam anything in it to clean it, you don't want to dammage the little filliments in it or you'll be out $400. Let it dry for a couple minutes then put it beck in hte same way it came out...remember to plug in the wire. Hope this helps, it worked for me.
Old Dec 3, 2003 | 03:24 PM
saskatchewan
Thanks for the suggestions
I can not adjust the timing since it is a distributerless system.
I have some carb cleaner so, I will try cleaning the sensor.
Old Dec 3, 2003 | 06:36 PM
seagull369's Avatar
seagull369
Well, I said did you check it. Far as I know you can still do that on a distributorless.
You might want to try using electric parts cleaner instead of the carb kind. It is electrical after all.
Old Dec 3, 2003 | 08:19 PM
Ken00's Avatar
Ken00
You can't adjust the timing without a scanner that allows you to access this parameter, its all computer controled.
Old Dec 3, 2003 | 09:49 PM
saskatchewan
Hey
When I had a parts store do an OBD II reading on the vehicle it kept giving a message saying that it could not give a reading.
Any ideas on why this is?
Then I guess I could check the timing and perhaps set it.
What is necessary to adjust the timing on a distributerless engine?
Old Dec 4, 2003 | 09:25 AM
Ken00's Avatar
Ken00
I would determine why you can't get anything from the PCM before doing anything. See my comments above about adjusting timing.
Old Dec 4, 2003 | 07:10 PM
seagull369's Avatar
seagull369
WHat part of CHECK are you folks not understanding. I said nothing about adjusting.
BTW, what makes you think you have a detonation problem?
