1995 explorer
Old Jan 16, 2025 | 10:29 PM
goldiggerguy's Avatar
goldiggerguy
1st Gear
1995 explorer
has any one had a no start on a 4,o due to no pulse to injectors, changd crank , cam sencors and fuel regulator, aslo has spark , an fule pressor , will start with starting fluid down the air box, ran fine when parhed hasent started since,
Old Jan 17, 2025 | 01:25 PM
shorod's Avatar
shorod
Welcome to the forum! Have you noticed whether or not the fuel pump runs non-stop when the key is turned to the run position, versus running for about 1 second to prime the fuel system, then shutting off? If if does run continuous, there's a VERY good chance the issue is due to bad electrolytic capacitors in the PCM. I just had this issue in my 1995 Bronco. I opened up the PCM and replaced the three capacitors (which showed signs of slight leakage) and it now starts first try with very little cranking. If the fuel pump doesn't run continuously with the key in the Run position that doesn't necessarily rule out bad capacitors in the PCM, it's just the running fuel pump is often a quick indicator that the capacitors need attention.
The camshaft position sensor on Fords of that era should not cause a no-start, but the crankshaft position sensor can. Since you mention you replaced it, you may also want to make sure that you have the spacing correct. Have you confirmed that you're getting a reliable pulse from the sensor?
-Rod
boaterdude83
Feb 7, 2009 12:39 PM
oojbearoo
Feb 2, 2007 03:42 AM
zonk3939
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jun 30, 2004 12:19 PM
mel_griggs
May 2, 2003 06:38 PM
