Hi, I am looking forward to replacing some parts in my car and I need some help with the parts number.
1. Looking forward to get saginaw power steering pump with bracket and line.
2. Looking forward to replace tierods.
3. Replacing upper ball joints.
4. Replacing lower ball joints.
5. Replacing steering rack rubber boots.
6. Replacing the rubber that's around the screw that holds the steering rack in place.
7. Might look forward in to serpentine belt conversion.
would post some pictures later and might add several things to the list.
So we determined 56 ford, but when you add aftermarket power steering, what else is has also changed from stock 56? Are you looking for a whole aftermarket kit to upgrade/modernized the front axle, brake, steering, suspension?
It had a mustang ii steering rack.
would post pictures tomorrow.
If you are wanting the Saginaw pump shaped like a can of ham you might have to do what I did and find the brackets from an Econoline van that had a 460 in it. I have a 351 Windsor that I changed to a Saginaw.
I have no idea if these brackets would fit a 460 ..
The position of this pump is the same as mine so it might fit but my compressor is above the pump, some companies sell serpentine kit but the placement of the compressor and pump are different that's the problem.
I think my bracket may fit the saginaw would check it tomorrow.
