Tcu location
Old Jan 7, 2025 | 04:46 PM
Hmcfly626's Avatar
Hmcfly626
Tcu location
I'm having a difficulty with my sct x4 programmer, and they are requesting that I send in my ecu and my tcu. However, I can't locate my tcu location in the 2017 f250. Could you kindly assist me?
Old Jan 7, 2025 | 05:06 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Google search came up with this...
The TCM is located above the drivers front wheel well shield below the inner fender. The drivers inner wheel well has to be removed to access.
T. Banning's Avatar
T. Banning
If it’s the same as a F150, it’s behind the passenger rear seat back, secured to the back panel
Old Jan 7, 2025 | 06:04 PM
Hmcfly626's Avatar
Hmcfly626
thanks ill take a look there
Old Jan 7, 2025 | 06:38 PM
T. Banning's Avatar
T. Banning
TCU, Telecommunications Module, not TCM, Transfer Case Module
Old Jan 7, 2025 | 06:59 PM
cpobst's Avatar
cpobst
TCM=Transmission Control Module.
Old Jan 7, 2025 | 07:11 PM
T. Banning's Avatar
T. Banning
Yes, that’s what I meant, it also controls the transfer case if I’m not mistaken
Old Jan 7, 2025 | 09:20 PM
ifrythings's Avatar
ifrythings
TCM is Transmission Control Module
TCCM is Transfer Case Control Module.
A tuner company would want PCM/ECM and TCM.
TCM is bolted to a bracket that’s bolted to the outside, top of the frame rail under the drivers door area.
Old Jan 8, 2025 | 04:10 AM
Hmcfly626's Avatar
Hmcfly626
no They said they wanted the tcu and ecu to figure it out. I keep telling them that the tunner is not working because it doesn't read the truck info or my car info. So we're just sending emails back and forth. It took them five days before they finally decided it was bad.
Old Jan 8, 2025 | 04:58 AM
ifrythings's Avatar
ifrythings
In this case they are calling the TCM a Transmission Control Unit, there is no way they would want your Telematics Control Unit
Old Jan 8, 2025 | 05:02 AM
Hmcfly626's Avatar
Hmcfly626
ok i will ask them again thanks
Joshua Howley
Sep 9, 2019 09:32 PM
wharthog
Jan 22, 2019 03:18 PM
bevdan
Feb 3, 2013 09:33 PM
Bigjl
Jul 23, 2011 08:51 PM
vcamaro42769
Sep 26, 2008 07:46 AM
