Lock Problems
Im 16 and i have a 1984 F150 4x4 SWB, 33" Wild Country's, Warn Hubs, 4-6" body and suspension lift, with the torque monster 300 I6.
Anyway, on the driver side door, when i go to unluck it the lock pin moves slight upwars but the door refuses to open, i have to get in on the passenger side. HOWEVER after the driver side door has been locked if the opening button it NOT depressed it will unlock and open fine, if i press the button before unlocking the door... i am locke out.... HELP!!!!
If the problem wasn't fixed after some door lock lube, I would pull the door panel off and see what is going on inside. Some grease in the proper areas might take care of the problem.
