Ford f100
Old Dec 31, 2024 | 11:30 AM
Randale fordf100's Avatar
Randale fordf100
1st Gear
Ford f100
I’ve been having all kinds a electrical problems with my truck starting out my dash lights anit worked in almost a year now my brake lights went out I replaced the bulbs and soon as I hit a bump it goes back out should I change out the connector for it and how would I go about splicing it together thanks any help I could get would be appreciated
Old Dec 31, 2024 | 12:24 PM
Max Capacity's Avatar
Max Capacity
Welcome to the Forum. You might find this link helpful, we all use that.
https://www.garysgaragemahal.com/1980-evtm.html
I assume your truck is a 1980, what engine is in it ?
I assume you have made sure all the electrical connections are corrosion free ?
I find my local NAPA can get most wire connectors, I'll assume other name brand auto parts stores can too. Most will tell you to buy local and don't buy the cheapest part you see.
Old Dec 31, 2024 | 05:18 PM
FuzzFace2's Avatar
FuzzFace2
Welcome to FTE
I would first start at the battery as that is where power for lights start.
Make sure the ground side is good. Battery> motor> to frame. You also need a 10 ga wire from the motor to the fire wall to ground the cab.
It also would not hurt to add a ground from bed to frame so it is grounded.
I would pull all the fuses and if they look bad replace. If you reuse them clean the metal part of the fuse before you put it back on the fuse box.
There is a plug under the brake booster that is from the main harness to the rear harness that runs along the frame. There is another plug at the left rear from the frame harness to the taillight harness.
Pull them apart, mainly the taillight plug, to make sure they are clean.
Being the brake lights are out I would look at the switch. Dose the switch have power in to it all the time and if the pedal pushed power out?
May want to recheck the taillight bulbs and sockets to make sure they are good.
You also say brake lights went out again do the turn signal lights work front / rear? What about 4 ways?
On the dash lights I bet they are burnt out and the colored caps frosted. What happens when you turn the head light switch left & right a few times anything?
I would replace all the bulbs and clean the socket contacts on the cluster and go from there.
Dave ----
Old Jan 1, 2025 | 02:32 PM
5starCabF-3's Avatar
5starCabF-3
1980 there is a ground wire under a screw behînd the taillight housing on both sides.
then multiple ground wires are joined together half way in between, you will notice a lump in the harness.
​tween.
This was an issue with mine and some crayz stuff would happen.
Then the dash light problem ended up being a ground wire between the intake manifold and the cab.
The taillight harness with a different way of grounding the taillights was changed on later year bullnose but I am not sure when.
Old Jan 1, 2025 | 02:39 PM
Max Capacity
I'm sure there must be a page in Gary's site in the EVTM that shows the ground wires.
Here's the 81's I couldn't load the 80. Oh, I see the EVTM for the 80 is a little different in the way its loaded.
https://www.garysgaragemahal.com/grounds.html
Old Jan 2, 2025 | 06:36 AM
FuzzFace2's Avatar
FuzzFace2
​tween.
I can tell you the 81 stye side beds also had the ground wires behind the light housings.
This is why I said to run a ground wire from frame to the bed somewhere as the frame should be grounded from the factory.
Later year trucks had a ground wire from the tail lights to inside the cab behind the radio on the firewall and why the cab has to be grounded.
Also from motor to cab to ground the cab as the motor was factory grounded.
Dave ----
Montemoto
Mar 1, 2024 02:24 PM
chuck3908
May 4, 2023 03:56 PM
devildogknapp
Jan 6, 2002 02:56 PM
