So I ordered a FIA quilted Winter Front/Bug screen for my new 2024 SD & this is what arrived? Any previous winter fronts I have ordered for other Ford trucks (F150 & Ranger) "fit" properly; does this look correct or should it cover ALL of the chrome
But, since you've got one... Will these mess with the finish on the grill? What does the back look like?
I have never noticed any issues on previous versions, but if it did "scuff" the grill, the summer bug front will "hide" it. For me it's a non issue & while others are meticulous about the appearance of there vehicle, to me it's still "just a truck" Yes it's a very expensive vehicle (never thought I would spend $90K for a truck ) but at the end of the day, if I worried too much, I would never want to move it from the driveway
You have 2 choices of mounting; you can drill the "snaps" into place or use the peel & stick snaps, which previous experience tells me work perfectly fine. This "works" fine for it's intended task, but aesthetically I'm not a fan
