Wet Driver Side Floor
Old Dec 27, 2024 | 05:44 PM
Oliviahill36's Avatar
Oliviahill36
2nd Gear
I drive a 2018 Ford F-150 XLT. Everytime it rains my driver side leaks from right underneath the center of the dash, like right above the brake pedal. It does not leak unless it rains. I’m not sure if it’s an ac drainage problem or something else. Sometime it leaks a lot and sometimes it leaks just a little bit, depending on the rain amount. Does anyone know how to fix this? I’m not sure what to do.
Old Dec 27, 2024 | 05:55 PM
SpencerPJ's Avatar
SpencerPJ
The ac drainage issue is on the passenger side. Sadly, I had to have a windshield replaced in my 2020. After a trip through the car wash, it leaked same as yours, straight up from brake pedal. They replaced it again, said no way to fix it.
Now if I was me, I'd certainly look for a way to pull back the trim and add some product like Geocell, black in color (it's similar to silicon, but not.)
Old Dec 28, 2024 | 03:54 AM
Oliviahill36
2nd Gear
Did you do the same to yours? I have Husky floor liners and when it rains I just put a towel right underneath the brake pedal so it doesn’t get into the carpet. Let me know if you did the same and I’ll probably look into doing that. Thanks.
Old Dec 28, 2024 | 08:00 AM
SpencerPJ's Avatar
SpencerPJ
No, they replaced the windshield again. If you go the caulk route, I'd stay away from silicone. I've heard it can react with aluminum. Google is your friend.
Old Dec 31, 2024 | 12:37 PM
shaun.be's Avatar
shaun.be
What about using RTV for this?
Old Dec 31, 2024 | 01:49 PM
SpencerPJ's Avatar
SpencerPJ
I guess it depends. Some silicone and RTV sealants contain acetic acid, that can attack aluminum. Given the aluminum is painted, I do not know what if any issue could happen. I would tend to look at aluminum gutter sealants, or polyurethane sealants, or get on amazon and find windshield caulk..
Old Jan 1, 2025 | 04:55 PM
fe390pc's Avatar
fe390pc
You can get a windshield sealant, but get it done as there are modules under the dash that get screwed up by the water leaking on them!
Alex22500
Jun 26, 2023 09:36 PM
EcoBeast18
2015 - 2020 F150
15
Jan 6, 2021 11:02 AM
1L243
65
Feb 26, 2013 10:24 AM
Javelin389
Sep 7, 2006 07:34 AM
fordwel
Jul 21, 2001 02:50 PM
