Sponsored by: Real Truck
Oh NO! Fabtech vs Edge
Old Dec 2, 2003 | 01:41 PM
ford 2 fitty's Avatar
ford 2 fitty
OK, I did do a search and found some details comparing the front leveling kits but I am interested in the 4.5 - 5.5 lift Kits.
Which do most people recommend? The Edge 4.5 or Fabtech 5.5? I am mounting a set of 35 Procomp Xterrains on a 2003 Ford Super Duty 250.
I am not concerned with company business ethics, just straight up performance and quality.......
Please post any pics if you have them...
Originally I was going with the Edge 4.5 but have know changed my mind and leaning towards the Fabtech 5.5..
Thanks
Old Dec 2, 2003 | 05:24 PM
DCSpecial's Avatar
DCSpecial
Well, from what I have seen if you have a PSD you'll get about 4.5" out of the Fabtech 5.5".
Being as the Edge 4.5" is a hanger and shackle, there is no change in spring rate. And since it also includes Bilstein 5100s valved specifically for the SD you'd have a better than stock ride. IMO, Bracketry is better on the Edge.
Fabtech is new springs......will change spring rate. Shocks aren't the greatest (I'd say to order the kit w/o shocks and order the Bilstein 5100s instead).
If you wanted to off road hard I would recommend a 6" lift instead.
Just my $.02
Hope this helps.
Old Dec 4, 2003 | 02:08 AM
Mizzou's Avatar
Mizzou
Had the 5.5 in mine and didn't get near what it says as DC said. I parked next to guy that had a 5 inch with same tires and his was about one inch taller than mine. If I had it to do all over again I would probably go with the Edge.
