Sponsored by: Real Truck
Stuck in 4WD LOW
Old Jan 4, 2003 | 09:23 PM
Manny6140's Avatar
Manny6140
Stuck in 4WD LOW
Wet snow. Did not lock hubs. Used the switch. Went to switch back but will not come out. Went backwards, checked switch. What next.??
Old Jan 4, 2003 | 10:50 PM
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
Stuck in 4WD LOW
[updated:LAST EDITED ON 04-Jan-03 AT 11:51&nbsp;PM (EST)]Step firmly on the brake pedal. What kind of vehicle is it?
Old Jan 4, 2003 | 10:55 PM
Manny6140's Avatar
Manny6140
Stuck in 4WD LOW
Truck is a 2001 4WD V10, 4DOOR, 50K Highway miles
Old Jan 4, 2003 | 10:59 PM
Jakebrake's Avatar
Jakebrake
Stuck in 4WD LOW
[updated:LAST EDITED ON 04-Jan-03 AT 11:59&nbsp;PM (EST)]Do you have Electronic Shift on the Fly switch on dash?
Old Jan 4, 2003 | 11:15 PM
Manny6140's Avatar
Manny6140
Stuck in 4WD LOW
Yes, and that is what I used. I popped the switch out to take a look at it. There were 4 wires going to it. Using a ohm meter it seems that the two end wires are for the illunimation. The two center wires respond to the three different positions on the switch with different resistance. Tried applying the brake firmly. No Change. 4WD Low Range still lit on the dash no matter what postion switch is in. Ttied reverse than forward. No Change.
Old Jan 4, 2003 | 11:24 PM
Jakebrake's Avatar
Jakebrake
Stuck in 4WD LOW
[updated:LAST EDITED ON 05-Jan-03 AT 00:28&nbsp;AM (EST)]If you are on a firm surface (not loose soil) then you might have to allow the truck to roll forward some, and then roll backward in reverse. While rolling in both directions, turn the steering wheel left to right several times. What is the temperature where you are?
Old Jan 4, 2003 | 11:38 PM
Manny6140's Avatar
Manny6140
Stuck in 4WD LOW
Tried that already. Drove around 10 miles on wet roads to get from the snowed in parking lot I was, where it got stuck in 4WD low to my house. The switch was in 2WD the entire time. Put it in reverse went backwards 20 feet. No change. Temperature during day was around 35 now it is around 28. I also went under the truck and inspected the electrical connections on the transmission and the transfer case. Everything is dry/unfrozen.
Old Jan 4, 2003 | 11:48 PM
Jakebrake's Avatar
Jakebrake
Stuck in 4WD LOW
[updated:LAST EDITED ON 05-Jan-03 AT 00:50&nbsp;AM (EST)]I had a similar incident with my 2001 Excursion (V-10 also) when it was new. I was pulling a trailer on Donner Pass (7200 feet near Lake Tahoe in California). I stopped to take it out of 4 low and had a devil of a time getting it to shift out of 4 low until I figured out that I needed to leave it in gear and firmly apply the brake. Sorry I could not help you sort it out...maybe someone else has an idea...Ken.
Old Jan 4, 2003 | 11:52 PM
run8's Avatar
run8
Stuck in 4WD LOW
Not trying to start a flame war here, but that is precisely why I didn't get ESOF!
-IKE
________________________________________________
[A HREF="http://www.ikemeyer.com/inlink/f250.html"]Cross dressin' 2000 Crew Cab with Excursion grill[/A]
5.4, 5 speed, manual 4x4, 4.10s w/ rear L/S, Superchips, K&N, Flowmaster
35 inch BFG's
Lifted 3 1/2 inches front and rear
Manny6140's Avatar
Manny6140
Stuck in 4WD LOW
Thanks for your ideas. I will try again in the morning - east coast out. Tom
Old Jan 4, 2003 | 11:55 PM
Manny6140's Avatar
Manny6140
Stuck in 4WD LOW
Never had a problem with my 1986 F150 4WD Locking Hubs only really do rule. Still have to get this fixed somehow. Still under warranty just a pain in my @##.
Old Jan 4, 2003 | 11:57 PM
Jakebrake's Avatar
Jakebrake
Stuck in 4WD LOW
[updated:LAST EDITED ON 05-Jan-03 AT 00:58&nbsp;AM (EST)]Let us know what the problem turns out to be when you get it repaired, it would be interesting to know...Ken.
Old Jan 4, 2003 | 11:59 PM
Manny6140's Avatar
Manny6140
Stuck in 4WD LOW
I will do that. May take a few days. See ya.
Old Jan 5, 2003 | 06:01 AM
FortyFords's Avatar
FortyFords
Stuck in 4WD LOW
What usually happens is, water gets in the connectors to transfercase,transmission and shorts out ,sometimes blows the fuses.
You must also be completely stopped with brake applied,because the vss
sensor is sending info to the 4wheel drive module which will prevent the relays from shifting.
Water also gets to the relays in the engine compartment (aux3 relays)
I bet if you can get the truck in a heated garage it will start working once it dries out.
We always used to take the connectors apart and put grease in them to prevent the water from doing this.
This not to say this infamous or common problem will ever be fixed
Because I hate ESOF just because of this situation!
Good luck !@
Rich
02 F250 4x4 SC 5.4v8 6spd 3.73ls Trueblue/Silver and Chrome Nerfs
"All Levers"
Old Jan 5, 2003 | 09:45 AM
Manny6140's Avatar
Manny6140
Stuck in 4WD LOW
It is out. Combination of patience with the brake on firmly, letting it roll back and forth. I had the door open and while in reverse, stopped with the brake on I heard something under the truck moving. Shifted into neutral and the 4WD Low light went off.
Thank you for getting me un-stuck.
PS: Going to put some grease on the electrical connections under the truck now.
