Seat Swap
Old Dec 20, 2024 | 12:51 PM
thekrajewski's Avatar
thekrajewski
2nd Gear
Seat Swap
Hello I searched for this topic but could not find, Looking to swap the 2023 seats into a 2020, will they bolt up? I assume I will need to worry about wiring? I have learned ford uses the same wiring harness consistently so not even sure we need to worry about that. If you guys have any insights it would be appreciated.
Old Dec 20, 2024 | 07:37 PM
JoeUser's Avatar
JoeUser
I found quite a few threads here on the forum related to seat swaps. Here are a few (the first two are informative, and topical):
https://www.ford-trucks.com/forums/1...18-lariat.html
https://www.ford-trucks.com/forums/1...-question.html
https://www.ford-trucks.com/forums/1...seat-swap.html
https://www.ford-trucks.com/forums/1...swap-help.html
The forum search feature is not too helpful sometimes. I've had better luck using search engines (DuckDuckGo, for example). The trick is to use the site:ford-trucks.com option.
I found the links above using the following search phrase: super duty 2023 to 2020 seat swap site:ford-trucks.com
Good luck in your seat swap quest, and if you're successful share the knowledge!
Old Dec 21, 2024 | 06:01 PM
acdii's Avatar
acdii
2023 is a new body design, so bolt placement may not be the same.
thomas h
2015 - 2020 F150
Jan 31, 2023 03:13 PM
fordman in alaska
2015 - 2020 F150
Jul 3, 2022 10:08 PM
BuddyB
Jun 3, 2022 09:42 AM
RigCity
Jan 13, 2021 04:17 PM
interquestk9
Mar 18, 2008 06:16 PM
