Bad temp gauge?
Old Dec 2, 2003 | 12:42 PM
MAHinton's Avatar
MAHinton
Bad temp gauge?
Has anyone here had experience with the factory temp gauge in a mid-70's F-series going bad? Although my cooling system seems to be working perfectly after replacing most of it, the temp gauge is still, at times, climbing way too high. Not all the time, not always to the same place. Enough to be annoying, though.
Sender, stat, pump, radiator, hoses, and coolant are all new, and normal operating temp on another gauge is showing 180-ish (with a 180 degree t-stat), and a thermometer in the filler neck of the radiator is showing about 170, so the truck itself does not seem to be overheating or running hot.
Thanks.
Matt
Old Dec 3, 2003 | 08:37 PM
Ultramagdan's Avatar
Ultramagdan
I would suspect a bad ground between the gauge and the ground. It is also possible the gauge is finally losing it.
Sean Doyle
Jul 16, 2016 01:57 PM
89f150beast
22
Jan 28, 2016 07:12 PM
bigb56
Aug 1, 2015 06:21 PM
blue924.9
Feb 27, 2015 04:05 AM
Steve_Uzi
Jan 11, 2004 06:42 PM
