'75 progect
Old Dec 2, 2003 | 12:34 PM
Elmo's ride's Avatar
Elmo's ride
Angry '75 progect
in the proces of changing intake man* gaskets, and taking the time to mark the dis. and rotor locations to prevent timing the motor. a friend turned the motor over and now i cant find out what intial timing should be,sticker is gone frome valve cover
Old Dec 2, 2003 | 01:54 PM
Elmo's ride
what an air head i forgot to state the engin size. which is a 390. also is there a dif. in initial timing between an electronic and a point type egnition
Old Dec 2, 2003 | 06:20 PM
Elmo's ride
this really blows,can't any body help? Cant find any info anywhere
Old Dec 3, 2003 | 08:24 AM
Sport45's Avatar
Sport45
You install the dizzy the same way with points or electronic. Pull the #1 plug (farthest from firewall on passenger side), roll the crank clockwise with a finger over the sparkplug hole untill you feel a blow. Stop when the 0° mark on the balancer lines up with the pointer. Put the cap on the dizzy and see where the wire to the #1 cylinder lines up. Take the cap off and put the rotor on. Instal the dizzy so that the rotor points to the #1 cylinder wire (it will turn a bit while going in). Satrt the engine and set the timing to spec (found in owners manual, Chilton, or Haynes manual). If you can't find the spec just advance it until it pings on acceleration and then retard just enough to stop the pinging. This will get you in the ballpark.
Geeze, you gotta give folks time to read and respond. None of us monitor this stuff 24/7.
Old Dec 3, 2003 | 10:22 AM
Elmo's ride
thanks for trying to help.I kind of know how to do that would like to know how many deg. befor tdc it should be set at.
tcoker79
Escape & Escape Hybrid
Jul 22, 2018 10:27 AM
adams.construction
13
May 9, 2010 01:09 PM
rmalottwtes30
Apr 6, 2008 11:31 PM
tcb89
1978 - 1996 Big Bronco
Mar 15, 2005 08:07 PM
Water Dog
Arizona Chapter
Mar 23, 2002 07:53 AM
