Cranking issue
Old Dec 16, 2024 | 02:51 PM
Gjorgjija's Avatar
Gjorgjija
Cranking issue
Hi folks,
last week finally I register my van and got the plates. Next morning I have issue with cranking.
Any help will be welcome.
Br
Old Dec 16, 2024 | 07:04 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Sometimes when it's cold out, the fender mounted solenoid can use a little "tap". Just lightly, like with the handle of a screwdriver. If you have help, put a test light or meter on the solenoid and see if you get power when you turn the key all the way forward.
Old Dec 17, 2024 | 07:13 PM
mattnj's Avatar
mattnj
Check voltage on relay terminals while turning key to start.
I did have same thing when my starter solenoid cable came loose on the solenoid terminal.
Old Dec 18, 2024 | 08:24 AM
Gjorgjija's Avatar
Gjorgjija
Yesterday it crank and start from first turn without doing anything on the rellay/solenoid/starter... very strange.
Old Dec 18, 2024 | 09:17 AM
mattnj's Avatar
mattnj
Inspect the wire from relay to starter solenoid and clean and retighten connections on relay and starter solenoid as a PM. And I would get a spare starter relay handy just in case.
yippee
Sep 27, 2023 06:38 PM
keith w
Car/truck Buying Advice
35
May 2, 2005 12:26 AM
DanB98TJ
May 27, 2002 02:44 PM
David Bese
Mar 19, 2000 09:43 AM
