Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Is This Standard Issue?
Old Dec 12, 2024 | 09:57 PM
hunts318's Avatar
hunts318
Another tidbit from today's labors, I thought I would lke to know if the following is standard Ford or was installed from Pierce...
I do not have airbrakes....
Is this vacuum gauge for the power assist to the hydraulic brakes?
Thank you,
Landon
Old Dec 12, 2024 | 10:00 PM
hunts318's Avatar
hunts318
P.S. I plan on tracing the hose to it's end tomorrow. Probably can glean it's function then.
Landon
Old Dec 12, 2024 | 10:42 PM
85e150's Avatar
85e150
Vacuum gauge should connect to the intake manifold-- or a vacuum reservoir.
That one looks added on but I think some trucks had them as OEM.
A vacuum gauge is sometimes used to help promote economical operation. As a safety item to make sure you have vacuum for the brakes i guess i could see that as well.
Old Dec 15, 2024 | 01:04 PM
Destroked 450's Avatar
Destroked 450
Although a vacuum gauge is not a normal item I’ve see then on Ford trucks before, that is a Ford gauge as that needle style was on the instruments in the LTL models I’ve owned and driven, pretty sure the air pressure gauge in my F-800 is that style and in the same location
Old Dec 21, 2024 | 12:01 PM
Louisville Joe's Avatar
Louisville Joe
That's stock, it was on all medium duty F-series trucks with vacuum booster brakes. The hose should go the the vacuum tank, not the booster or intake manifold. Sometimes I believe it was tee'd off the check valve on the dash. It was a safety item to let the driver know it he was losing vacuum, because with no vacuum there was no brake boost. It should dip momentarily when stepping on the bakes with the engine running.
Old Dec 21, 2024 | 10:34 PM
garygnu's Avatar
garygnu
I put a vacuum gauge on my truck for just that reason ,it reads 20 at idle
Old Dec 22, 2024 | 12:48 PM
Destroked 450
Assuming that was a 80’s thing, I’ve seen vacuum gauges on a few 60’s/70’s models but most of the F-600/700’s I’ve been around didn’t have them
RonaldN0519
115
Aug 8, 2025 10:30 PM
fordfan76
Jun 11, 2022 10:19 PM
Joshua Ade Richards
Large Truck
May 9, 2022 04:49 PM
Gaugepro
26
Feb 22, 2016 12:34 AM
benbuilder
Aug 19, 2015 05:45 PM
