Coolant leak
Old Dec 12, 2024 | 09:00 PM
Grandude's Avatar
Grandude
5th Gear
Coolant leak
My first time here. I have a 2017 F350. It has a coolant leak but it only leaks when it is not running. I am pretty sure I found where it is leaking but am not sure what the part is called. Also I am not a mechanic but I am not completely helpless either. If this is something that would be better off for a mechanic to fix please let me know before I bite off more than I can chew. Any help or a point in the right direction is appreciated.
Old Dec 12, 2024 | 10:45 PM
Papa Tiger's Avatar
Papa Tiger
Good to see you here Grandude. It looks like the assembly should be replaceable. Looks messy and draining 1st.
Go up to Ford with the pictures, they can offer advice on the parts. Something most likely stressed the area. Pothole ?
I have plenty of them here. Front wheel bearings are my cost.
Old Dec 12, 2024 | 11:17 PM
Grandude's Avatar
Grandude
5th Gear
thank you. I do put alot of stress on the truck. I use it to pull campers all over the country. So a lot of miles with heavy loads.
Old Dec 13, 2024 | 11:04 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Yeah, shouldn't be too bad to replace.
Welcome aboard!
Old Dec 15, 2024 | 11:35 AM
Grandude's Avatar
Grandude
5th Gear
Update
I ended up taking it in to a dealership and had them fix it because I had no where to drain the coolant. The part was about $70 plus a couple of o rings that needed replaced. With labor it ended up being about $275 Thank you for the advice.
Old Dec 16, 2024 | 09:41 PM
CathedralCub
FTE Community Team
Glad you got it worked out!
Sounds like they went easy on you with the labor.
That's refreshing!
Eastx
New Member Introductions
Mar 28, 2024 12:01 AM
AzSideWinder
Sep 4, 2021 06:44 AM
Stormtruck2
Aug 24, 2019 11:13 PM
FORDF250HDXLT
134
Sep 12, 2017 06:40 PM
