Lean condition
Old Dec 12, 2024 | 02:00 PM
bronco6767's Avatar
bronco6767
Lean condition
I have a 2005 f150 5.4 and I'm getting a lean code for bank 1. Truck has 195k miles on and was sitting for about a year. Truck starts right up and runs but has a shake to it even tho NO missfire codes. Any recommendations where to look? High fuel trim on bank 1 would indicate vacum leak only affecting pass side bank 1? And when revved fuel trim sky rockets last pic is revved at 2500 rpms.
Old Dec 13, 2024 | 08:57 PM
SDDL-UP's Avatar
SDDL-UP
Try changing the fuel filter. Cheap and certainly due if it's never been done.
Old Dec 13, 2024 | 09:00 PM
bronco6767's Avatar
bronco6767
I'll try that this weekend. I'm also planing to do a fuel pressure test tomororw, waiting for adapter for my kit to arrive.
Old Dec 17, 2024 | 01:15 PM
bronco6767's Avatar
bronco6767
KOEO- IS 35PSI
KOER- is 35 psi
so my fuel pressure is at very minimum for on and off. Would that be a factor?
Old Dec 19, 2024 | 04:10 PM
SDDL-UP's Avatar
SDDL-UP
Not sure what to tell you. Are those pressures after a filter change?
Old Dec 19, 2024 | 04:44 PM
bronco6767's Avatar
bronco6767
yes just changed the filter
Old Dec 19, 2024 | 05:20 PM
bronco6767's Avatar
bronco6767
Old Dec 21, 2024 | 11:58 PM
SDDL-UP's Avatar
SDDL-UP
I would think even AT MINIMUM you should be okay. Wish I knew what to tell you.
jfwainscott
29
May 28, 2024 03:31 PM
bigwin56f100
Oct 6, 2021 10:17 AM
Rauly 302
Jan 22, 2020 03:25 PM
Squirrel13
Oct 30, 2019 10:12 AM
