Wooden Bed Liner?
This is my truck for reference
I am planning on using my truck this summer for photo opportunities and will also be selling flowers out of the bed. Just trying to have a little fun as a college student and make a little money doing something I enjoy😁
do you have any suggestions?
If you are talking about a wood floor like they had in truck flare side trucks or trucks from 40’s and 50’s, there are already kits to do that.
now make it out of wood and it will become way to heavy and large for one person to move. probably will be a 3 or 4 man job to take it out and put back in.
i would go with spray in liner that you can color shade to your choice.
I'd use redwood or cypress. You can stain these and they really don't need a sealer. Both will fade somewhat over time in the sun, so expect to re-stain them once in a while.
I assume you will have the long parts running front-to-back, and some sort of cross-piece to fasten these together. A beveled cross-piece mortised to fit the open end (at the rear) could provide a functional and attractive, ramped transition up to the rails.
If you use solid cross pieces you might have trouble getting it out unless you make it in two sections (a left and a right, with an overlap in the middle to hide the seam). But this will produce the most rigidity and you can place the rails close together.
If you use braided nylon, or other flexible strapping, you can roll it up (side to side) and stand it in a corner of your garage when not needed. Velcro bands or bungie cords can keep it together in storage. You'll need to leave space between each rail to allow for the rollup. It also won't be as rigid and you might have to make some adjustments to get around/over the bed bolts and other things. Matching spacing to the grooves in the bed might be good, or not, you'll have to see how that works for your plan.
Good luck!
Good luck!
Pulled it out to put in a spray in bed liner, which I didn't like. Im not a fan of the spray in stuff, almost impossible to load and unload things, wont slide, fork lifts cant push things on it without tearing it up. It looks nce though. Personally I like plastic or wood for working uses. These wood ones are fairly common in western Canada.
I thought when we pulled it out it would be nothing but a rusty mess under it (Didnt get a pic of it until it was sanded down). But it looked brand new under it, bieleve it or not. It was in there for quite a few years, always outdoors, dont rember how long, probably 8-10 ish yrs. Fair job to make one though, and youre not pulling it out with taking it all apart. It wasn't there to look pretty either though. It can also leave you with splinters if you're not careful when it starts getting too worn and beat up.
I had a real nice hardwood floor in my '58 Chevy. Only problem is, you dont want to put anything in it, or even walk in it, its too nice. It'll get wrecked pretty quick. And takes some time to keep the wood looking nice.
EDIT: Great for a show truck or strictly working/industrial use truck, not so sure I'd want wood for a personal daily use truck. I thought about it for my '96, but stuck with plastic. My '06 has a spray in liner. Both for personal use are great.
Food for though for you. Good luck with it.
I dug up a couple pics.
The plastic isn’t perfect and is lifting in spots, would that make it easier to remove?
Plastic does tend to warp in the sun after time. Ive screwed them in to the bed to hold them down when they do that.
that liner looks in nice shape, not beat up.
