I recently bought a 1997 f350 , I’m having trouble with the power locks . I took the driver side door panel off, didn’t notice any broken wires. I have power to driver door lock buttons, power to fuse box. I jumped wires to door lock actuator the locks went up and down perfectly. I need help with finding either a relay or module. Not sure if this truck originally had power lock fob, not sure if that could be the problem. Any suggestions would be appreciated
Here are the wiring diagrams. The link is to a website so you can navigate back to get more detail. Looks like relays are involved with remote anti theft module.
Maybe it is a ground problem at the frame or wire from the solenoid to the frame.
I assume your truck is southern but nearing 27 years of rust?
Most likely the problem is near the fuse box or the doors.
I tried tracking down a relay , not sure truck has one. I put 12 volt power to actuator on driver door and the lock worked perfectly.I have power to switch , I have new switch on driver door
Use the wiring diagram to measure the voltages at the lock and unlock terminals at the switch. Push the lock button and verify one terminal is 12v and the other is GND. Then press the unlock bottom and the signals should swap positions. You may simply have a bad ground. A voltmeter and the wiring diagram will solve the mystery.
