Side emblems
Old Dec 9, 2024 | 12:35 AM
Stens80's Avatar
Stens80
Side emblems
Hi,
Anyone know what type of emblems fit these 4 holes on the pic below? It's the same on the other side so I guess there should be emblems?
250 Ranger XLT 1970 4WD (highboy) - And should there be anything on the bed? I have been told my car is a camper since i have the tool box on the side. Anything else to look for to verify this?
Google did not help me so trying my luck
Old Dec 9, 2024 | 07:17 AM
fe390pc's Avatar
fe390pc
Those were for some type of mount/bracket, not emblems. I had similar holes with brackets on a camper special I parted out, believe it had to do with supports for the camper.
Old Dec 9, 2024 | 11:17 AM
tcanthonyii's Avatar
tcanthonyii
Could be as FE says or could have been a dealer logo. I pulled some dealer logos off this weekend that had holes drilled into similar locations but not in that orientation.
Old Dec 9, 2024 | 02:18 PM
RichS2659's Avatar
RichS2659
Camper Specials were only 2wd. The toolbox option was available for 8 ft bed trucks. As per ND.
Is that a 3 speed manual shifter or an automatic?
Old Dec 9, 2024 | 03:20 PM
Green72F250's Avatar
Green72F250
I agree with fe390pc that these holes were for a bracket for a camper, as seen in the picture below (not my picture):
Old Dec 9, 2024 | 11:49 PM
Stens80's Avatar
Stens80
Hi, It currently has a C6 but if I decoded the VIN correctly it should be a manual.
VIN F26YRJ33276
F26 = F-250 4WD
Y = 360 cid, 8-cyl.
R = San Jose, CA
J = J30,000 thru J49,999
Second row: 131(space) F260 3(SPACE)3 A 24
131 - long wheelbase truck is 131
MINE HAS NO COLOUR CODE SO I AM GUESSING IT’S A CUSTOM ORDER?
F260 = F-260 (4x4) GVW 6,800
3(space) = Mine is Parchment, what ever that means 😉 no interior code - The first two digits are the interior trim code (If only two characters are needed for the trim code, there will be a space between the first and third digits. In the example pictured here (click to enlarge), you can see the three-digit body code, where the second digit is blank. "D-4" would indicate a Sport Custom cab with styleside box
3 = (body style) this is where I get confused. Should it be a flareside? if yes the bed must have been changed ofcourse.
https://www.fordification.com/tech/VIN70.htm
A = 4-Speed New Process 435 – ( my car has a C6 automatic 3 speed) has it been changed. What can I look for to confirm this?
24 = 4.10 (5.20) Dana 60
If I have decoded this correct…
Old Dec 10, 2024 | 11:48 AM
Green72F250
Parchment is the light tan/grey color as seen in this picture for a 1972 truck, you can look up some information that might help with your truck using this:
Upholstery 01 | FORDification Factory Literature Library
Old Dec 10, 2024 | 02:06 PM
RichS2659's Avatar
RichS2659
From a previous post photo, it looks like it has a 67-69 bed without the rear marker lights, and has no trim level emblems. You can pull a Marti Report for its Ford birth certificate to know for sure. 4wd trucks didn't get automatics until 73 so it was swapped in. What transfer case do you have: a divorced Dana 24, divorced New Process 205, or a married NP 205?
Old Dec 11, 2024 | 02:39 AM
Stens80's Avatar
Stens80
Pic of bed
Can you tell by this? Looks like 24?
Old Dec 11, 2024 | 07:18 AM
fe390pc's Avatar
fe390pc
Yes, that is a 24
dedward
21
Mar 5, 2021 05:12 PM
HondaRider137
Nov 29, 2019 05:52 AM
Natemckenrick99
Oct 17, 2017 06:28 PM
redz284u
Jan 17, 2017 03:58 PM
krisg
Dec 7, 2013 10:21 PM
