Upper oil pan leak
Old Dec 6, 2024 | 11:49 AM
First3Quarter's Avatar
First3Quarter
Upper oil pan leak
As the title suggests, is this the upper oil pan leaking?
2017 F250
2017 F250
2017 F250
2017 F250
Old Dec 6, 2024 | 03:16 PM
Strider250's Avatar
Strider250
This should probably be moved to the 6.7 forum.
Old Dec 6, 2024 | 05:05 PM
CascadeF250's Avatar
CascadeF250
I had 2 upper oil pan leaks 10,000 miles apart on the 16 that I had. Most of the time the oil pan leaks were on the driver side on the front part of the oil pan. If that picture is in that spot it probably is the notorious leak. There were a few timing cover leaks in that area also.
Old Dec 6, 2024 | 08:54 PM
First3Quarter
Well crap. Post in the wrong forum?
Old Dec 6, 2024 | 09:54 PM
4wd6.7L's Avatar
4wd6.7L
Not really, the 17+ section gets all types of questions related to the 17+ SD, including mechanical, engine related questions. The 6.7l section can sometimes be better and generate more feedback.
Old Dec 7, 2024 | 07:35 AM
Pbergmann's Avatar
Pbergmann
That will keep all the unpainted metal parts from rusting!!
Old Dec 7, 2024 | 11:46 AM
First3Quarter
It already looks like my truck struck oil. I have the ccv reroute running down the left frame rail. Drips out just in front of the of the left rear tire.
jtg88
May 29, 2024 01:19 PM
Mastertinner
6.7L Power Stroke Diesel
Dec 31, 2023 11:49 PM
GOODOLEF250
May 9, 2019 04:07 PM
Kylef25008
Feb 26, 2017 10:06 PM
jedimaster69
Oil & Lubrication
Jul 12, 2011 12:19 PM
