9" Identification
Old Dec 4, 2024 | 05:03 PM
gogoat's Avatar
gogoat
9" Identification
Can anyone help me Identify a Ford 9" center section I have..
Old Dec 18, 2024 | 01:36 PM
G2IC_Wraith's Avatar
G2IC_Wraith
By FAR, not an expert, but visually it looks like you actually have a 1962-1966 8" center section.
I believe the case webbing you normally see on a 9" is missing & it looks like an 8".
This article has some visual clues so maybe it will help:
https://maliburacing.com/ford-nine-inch-g-body/
Old Dec 18, 2024 | 07:14 PM
gogoat's Avatar
gogoat
Thanks G2IC, I think your right. I do not think anyone wants this, It probably needs rebuilt. It will probably go in the junk steel trailer
Old Jan 4, 2025 | 01:18 PM
gogoat's Avatar
gogoat
It has 42 teeth on ring gear and 15 teeth on pinion. Divides out to 2,80 gear ratio. Is this correct?
Old Jan 8, 2025 | 11:17 AM
G2IC_Wraith
For those of us that shouldn't trusted with math... (yes, that's me sometimes)
https://www.crawlpedia.com/gear_tooth_calculator.htm
Yes, if your tooth count is correct it should be a 2.80
56exp
Sep 20, 2023 04:41 PM
Metalmagic
Feb 8, 2023 10:11 AM
firstrider
May 22, 2022 07:12 PM
Christmas
13
May 18, 2021 11:06 PM
firstrider
Feb 25, 2020 10:06 AM
