1978 - 1996 Big Bronco
Disappearing Coolant
Old Dec 2, 2003 | 04:32 AM
pointer94's Avatar
pointer94
I have a 94 with a 351w and for some reason I seem to be losing coolant. I check it every couple of months and it always seems low. The oil is clear and there is never a drop of coolant in the garage, and the overflow is dry.
Where is it going? I had the system worked on about a year ago and had all the lines replaced. This one got me stumpfed.
Doug
Old Dec 2, 2003 | 07:20 AM
Spud7's Avatar
Spud7
I had the same thing going on with my '92 and it turned out I had a leaking intake. The coolant was evaporating as it hit the exhaust so I never found any on the ground.
- Keith
Old Dec 2, 2003 | 08:47 AM
bronco351's Avatar
bronco351
A very common place for Bronco's to lose coolant is from the thermostat housing. After a few years these things being made out of Aluminum tend to not seal too good.
The way to tell if it is leaking is, fill up your system with coolant then drive the truck for 10 minutes. Get out pop the hood, and look with a flashlight directly under the thermostat housing. You will see a nice little puddle of green coolant.
There reason this never shows up on the ground is becasue it drips into a little crevice on the engine block, as the engine heats up it begins to evaproate it.
If this is in fact your problem, you want to remove the thermostat housing (only 2 bolts) and inspect it for warpage or damage. If it is in good shape, pop in a NEW thermostat ($5) and a new gasket ($2). Also don;t forget to use RTV WITH the gasket.
Hope this helps.
Old Dec 2, 2003 | 08:56 AM
BillyBob69's Avatar
BillyBob69
Another thing to check is inside the cab, on the passenger side. This is only if you smell coolant at all inside, especially when you are running the heater. Check your carpeting directly under the dash on the passenger side. all the way up to the firewall. If it feels sticky, or damp, then you may have a leaking heater core.
Old Dec 2, 2003 | 09:18 AM
JBronco's Avatar
JBronco
It is probably coming out of the coolant recovery tank cap. Most of them seem to do this and unless you see it right after driving, before it dries, then you won't notice it, and after a few months you will be low.
I put aluminum foil under the coolant recovery tank cap to stop this.
Old Dec 2, 2003 | 12:09 PM
Norm Carter's Avatar
Norm Carter
On my 86 302 it was the intake gaskets. It would usually evaporate from engine heat but if I parked it for a week or so there would be a drop or two off the bell housing. I used a radiator pressure test kit loaned from the local Auto Zone. I could see some coolant on the left top where the intake meets the head. I dried it off then pressurized the system and sure enough I could see it leaking. Not a real fun job to replace but it's nice to have no more leaks. If you do this repair I'd consider new valve cover gaskets at the same time.
Old Dec 2, 2003 | 02:44 PM
modemman's Avatar
modemman
Another spot that will develop leaks is the timing chain cover. Noticed this after I finished replacing the chain and gears and had everything buttoned up. DOH !
Old Dec 2, 2003 | 04:58 PM
Kemicalburns's Avatar
Kemicalburns
check your plugs, because a head gasket can blow inward allowing a small amount to enter and it gets burned up. this was what happend to my 88 302 that had 168k on her.
late
Old Dec 2, 2003 | 05:19 PM
JBronco's Avatar
JBronco
Yes, I was about to suggest that as well. Could be a head gasket.
I once had a 1974 Buick Regal that would empty the radiator every two days. I never saw a drop of coolant, or any white smoke or water from the tailpipe, and the car ran perfectly as long as I kept water in it. I used to fill it every morning.
I never did find out what the problem was, I drove it that way until a rod went and I junked it. But it had to be a bad head gasket or cracked block/head.
Old Dec 2, 2003 | 05:49 PM
Dutch123's Avatar
Dutch123
I notice coolant overflow residue around the coolant reservoir cap and overflow tank
Old Dec 2, 2003 | 07:18 PM
Black Ford XLT's Avatar
Black Ford XLT
intake manifold leak
Seems my 92 leaks from the bell housing when the weather turns warm (sunny day 70 plus )(been sitting a while)week or so,i feel its the intake manifold (freeze plugs r in good shape)small puddle will form under the truck( bell housing) .Now if i drive it dailey, i never see a spot on the ground and itll still lose a little with in a months time. TR
Old Dec 2, 2003 | 07:23 PM
KeelarPluto's Avatar
KeelarPluto
Thermostat and Water pump are always good to look at first, easy to notice without ripping anything apart.....I just noticed my thermostat housing is leaking today After I already flushed the system and put new upper and lower hoses on, bummer....
