Sponsored by: Auxito
No heat?
Old Dec 4, 2024 | 07:03 AM
waldo16's Avatar
waldo16
No heat?
I have a 97 F150 that currently has no heat at all. I’ve replaced the blend door actuator and took a look at the blend door and it’s still in solid shape. My coolants at the right level but still a little brown, I flushed it the best I could a while ago. The heater core is also flushed and the thermostat is brand new also. Any suggestions?
Old Dec 4, 2024 | 02:18 PM
Jon Freeman's Avatar
Jon Freeman
Check the temperature of the hoses to and from the core. One should feel hot ( the inlet line ) and the other cooler (return line).
If the temperatures seem right then it's not the coolant flow. It's likely the door is not positioning correctly.
If it doesn't seem right, then you have a coolant flow problem and will need to trace the problem back though the system.
Old Dec 4, 2024 | 04:03 PM
BareBonesXL's Avatar
BareBonesXL
Has it ever had heat since you've owned it?
Old Dec 4, 2024 | 10:19 PM
waldo16's Avatar
waldo16
No it has never had heat since I’ve owned it.
Old Dec 5, 2024 | 07:51 AM
waldo16's Avatar
waldo16
Both heater hoses are hot to the touch, both felt the same temp. I’m not sure what it could be, the blend door opens and closes just fine.
Old Dec 5, 2024 | 10:49 AM
Jon Freeman
If the heat is not being transferred to the core then the positioning of the door must not be correct. There's no other explanation I can think of. Maybe someone else will have a suggestion.
Old Dec 5, 2024 | 11:16 AM
BareBonesXL
Not clear how you know the blend door is in "solid shape". Did you use a borescope? It's not visible from the outside. Also, have you actually confirmed that the actuator is spinning its shaft? There's a video out there somewhere showing how you can see the shaft of the actuator moving. There's also one out there showing how the bottom of the door at the actuator can be fine but the door itself can be broken off of the main shaft.
Here's a couple of vidoes. I'd start by watching the shaft and listening for the door to thud when it opens and closes.
Here's one showing how what a properly functioning door sounds like. At 7:35.
Here's one showing how things work.
Old Dec 5, 2024 | 06:57 PM
waldo16's Avatar
waldo16
https://youtu.be/bflILISR1AE?feature=shared
https://youtu.be/zmOlDQQXlkw?feature=shared
I ended up ordering both the blend door and the actuator. I cut behind the glove box to get to the blend door and the actuator was opening and closing the blend door just fine. My heat blows lukewarm air when the engines warmed up but it goes back to being cold as soon as I turn the fan speed up.
Old Dec 5, 2024 | 07:07 PM
Jon Freeman
That's different than "no heat". That implies the heater core is clogged and hot water is not able to fill the core. You said it was flushed but flushing may not remove the clog.
Old Dec 5, 2024 | 07:10 PM
RLXXI's Avatar
RLXXI
If both hoses are hot to the touch and blend door is working, only thing left is the core itself is plugged. Inside or out. I've seen them get blocked up with leaves, road grime etc in the box. Might be full of stop leak from a previous owner that had a problem.
Old Dec 5, 2024 | 10:05 PM
waldo16's Avatar
waldo16
I went back and pulled the cut piece behind my glovebox again and turned my heat on with the engine completely warmed up and there was no airflow through the heater core and it was cold to the touch and the only air coming out was through the AC condenser next to it. Not sure if I should back flush it again to see if that will work or if I should tackle trying to replace the whole heater core instead.
Old Dec 5, 2024 | 11:47 PM
BareBonesXL
RLXXI was talking about air flow AND/OR coolant flow. Backflushing helps coolant flow but not air flow.
Pretty sure that fresh air from the cowl vents is supplied for every setting except MAX AC. You could have a blockage anywhere from the cowl vents (the grill at the base of the windshield) to the heater core itself. Could be a mouse nest, could be a years-long accumulation of stuff.
Looks you found a target either way. No air flow, no heat transfer. I haven't looked at the F150 cowl vents but typically there's a large cavity under those grills that the system pulls from. I'd start there. Make sure it's clear.
Old Dec 6, 2024 | 01:42 AM
Jon Freeman
If air is coming through the AC then the cowling must be open enough for air flow. Although when set to heat there should still be air coming across the heater core if the blend door is positioned correctly.
If the heater core is cold to the touch then the hot water is not going through the entire core. Since both hoses are hot there should be some flow through the core. Check the temperature near the top of the core near where the lines are attached. Otherwise something's not adding up....
If it is warm/hot at the top of the core and cold at the bottom then it is clogged. I would try flushing again, (can't hurt ), if it doesn't help at all then it would be time to replace the core.
Old Dec 7, 2024 | 01:33 PM
waldo16's Avatar
waldo16
I flushed it again and nothing nasty came out, just coolant. I think replacing the core could fix the issue. Any thoughts?
Old Dec 7, 2024 | 01:42 PM
BareBonesXL
Another part of the flow path that could be blocked might be the restrictor in the supply hose to the heater core. I don't know much about it but have heard that one exists. If the core flows freely (you haven't really described flow rate through the core - is it a lot, a gusher, or a dribble?) then you might check the supply hose.
If you replace one freely flowing heater core with another freely flowing heater core you probably won't see any change.
Found an old thread about the restrictor. It's basically a plug with a small hole in it. Could easily get jammed with crud. Should be easy to locate, if you have one.
https://www.ford-trucks.com/forums/1...estrictor.html
