Noisy Door
Old Dec 2, 2003 | 04:10 AM
GeneStoner's Avatar
GeneStoner
Noisy Door
When I close my passenger side door, the hinge makes a loud metal BANG when the hinge-spring rolls over the little hinge-wheels. The wheels LOOK alright and the door isn't crooked, so what causes this annoying noise?
Old Dec 2, 2003 | 04:35 AM
Torque1st's Avatar
Torque1st
Posting Legend
The roller is probably half frozen and binds up.
Old Dec 2, 2003 | 11:54 AM
stephenw's Avatar
stephenw
You might also take a look to make sure that the front of the door isn't rubbing on the fender. If the hinges are getting "well broken in", there could be just enough sag to allow that. I had to loosen my fender and give it a little shove to stop that same kind of noise. Steve
Old Dec 2, 2003 | 01:04 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Gene, my truck does the exact same thing when the rollers run out of lube. WD40 doesn't cut it. I use a teflon spray which works awesome.
Old Dec 3, 2003 | 09:27 AM
73Custom's Avatar
73Custom
Mine too. That noise tells me it needs some lube...
Marty
Old Dec 3, 2003 | 06:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Sometimes the rollers get a flat spot due to no lube. If you are in that situation replacement is in order.
