Smog pump delete
Old Dec 1, 2024 | 09:33 PM
F150 88's Avatar
F150 88
Trailering
Smog pump delete
All right got a genuine question my smog pump is chirping making noise sounds like a lifter noise/exhaust leak although I took the belt off the motor cranked it ran it motor sounds great so I grabbed the pulley on the smog pump bearing is dry and making a howling noise when I spin it so question why can't I just take off the three bolts that hold the pulley on and then go buy an alternative belt will there be any issues with me doing that and by taking off the pulley is so the alternative belt will clear or will exhaust come through the smog pump and into the engine bay will I need to delete that, and yes I know how to just wondering if I can get away with my idea thanks
Old Dec 1, 2024 | 09:41 PM
2015 F-350's Avatar
2015 F-350
That's what I did back in the day. Worked fine for me.
If yours has cats might be an issue, but I didn't have them so no issue.
Old Dec 2, 2024 | 10:24 AM
wwhite's Avatar
wwhite
I recently read a post that it can where alternator bearings, How? maybe because there is not as much surface area of the belt on the pulley, I don't know.
Its a bugger trying to find the right size belt.
I'd pull the smog unit, fix the bearing, your done.
Old Dec 2, 2024 | 12:44 PM
1Butcher's Avatar
1Butcher
If you have nothing to compare it with, it's hard to tell if a smog pump is bad.
They are all dry. There is no oil to lubricate anything. They are hollow so they all sound bad if you do not know what a bad one sounds like. Ford makes a bypass bracket/pulley for small blocks. I would not want to remove the pulley because the distance from the alternator to the crank is too long for my liking. I took my pump out and disassembled it. I could not figure out how to put all the pieces back in, so I left them out. Now the pulley just turns nothing. Basically, it was a quick/cheap way so I could deal with getting a bracket later. I've since ordered and received the bracket. Just need to put it on.
Poweredbyford87
May 10, 2021 11:25 AM
alanber
Sep 6, 2018 07:16 AM
luconn3
Feb 5, 2012 02:15 PM
fitmonkey1219
1997 - 2003 F150
Sep 2, 2007 06:28 PM
Ted's 92 Nite
Apr 20, 2007 09:55 AM
